Can not ping Default Gateway
I have a computer that has linksys lne100tx fast ethernet adapter.
I have configured static IP address for the computer, I can ping loopback, the computer own ad...
Hi
I have a Toshiba satellite laptop connected to my home wirless network.
I am unable to get my internet to work. I tried using an ethernet cable as well to connect to my router. But stil...
I have one Zyxel P700 series G.SHDSL model/router that I can use to connect to the internet. This modem/router doesn't has wireless capability but I have another Linksys WRT350N wireless route...
We just purchased a CISCO 2821 router so we can upgrade our Internet connection in our office. We also purchased two VWIC2-2MFT cards to plug into the router. The issue we are having is comi...
I have a sonicwall pro 2040 that the web management was taken off but the https was left on so I tried to access it on the internal network with https:/192.xxx.xxx.xx but i get no where after ...
I have planned out a DMVPN deployment for use as backup links into our main datacenter if our remote branches were to go down. I am just having some trouble trying to place my DMVPN hub router...
I have 2 x Linkstation pro's (LS-500GL) in an W2000 AD environment.
Until a couple of weeks ago all worked well, but now I have just realised I cannot access them through the network.
The we...
Network core switch is a linksys SRW 2024. It is capable of gig but is this a good switch for the core of your network. We have about 100+ users and 20 servers. I am not sure on what the pr...
I'm installing and configuring VMWare and I would like to install a 2nd NIC. Any recommendations? I will be running Windows SErver 2003 and MOSS 2007
I recently upgraded our DSL service with AT&T. The old service (still working) had a modem with 5 fixed IP addresses. The new service has a Netopia modem-router-access point. I think I still n...
We have software on a server that need to send data via FTP with TLS/SSL to an external site. We can connect to the FTP site but the ftp server drops our connection becuase of an TLS/SSL...
Do you use cross-over or straight through cable to connect to an ehternet wall jack or does it not make a difference.
The cable behind the wall jack then runs into a patch panel on ...
I am looking for information on how to setup 802.1Q VLAN on two Netgear GS724T switches.
The correct use of VLAN ID in conjunction with assigning defaul VLAN and selecting Taged and Untaged v...
I am about to setup my office network and I am about to buy a 300 m bulk CAT 6 cable. There are some details on these cable I do not understand. What is STP, FTP, UTP +++ for the CAT 6? What i...
We have 2 locations on our recent VoIP deployment. The VoIP system is an ESI-50 Communications Server (www.esi-estech.com) running at a corporate location and 3 remote VoIP phones running abou...
I have not been able to get my ISDN dial backup working. I had another open question about this back in October and was not able to follow up on my side. Any help would be appreciated. Conf...
I have been experiencing a recurring problem with a Cisco 877 Router.
Without explanation, the router appears to freeze. I lose internet connectivity and am unable to ping any external IP's...
I have followed the step-by-step instructions in the install guide for use of this print server, with no success. I have a HP LaserJet 1005 (USB connection) and an Olivetti PR-4 (LPT) installe...
I have a Cisco 3750 that i need to clear the arp cache on. when i run show arp command i have and IP address that is mapped to the wrong MAC address. It is causing a machine to state there is ...
I have had to replace my Windows SmartPhone from Cingular/AT&T 5x in the last few months. I have deleted profiles in ActiveSync and performed syncronizations with all phones mutltiple times. ...
How do I find the IP address of my Sun server? I have a Sun Sever in my office, running some form of linux -- terminal/command line only. It is on a rack server, and I know that it might see...
What is the life cycle of a Cisco Catalyst 3560 switch? Or when does Cisco stop supporting the switch?
We are currently using Checkpoint at our head office and one of our remote sites. There is a site to site VPN and users at teh remote site use Checkpoint user accounts and Radius authenticatio...
I have a printer installed locally through USB. The local computer needs to connect to a remote server and then print from it to the local printer. I checked the box in Remote Desktop ...
1) I just bought the Cisco 1720 Router from Ebay
2) It has already got the IOS Software
3) My Goal: i) I want to play around with this Router, ii) I want to UNINSTALL and INSTALL back...
