2000 organizations, including eBay, Ericsson, and Lockheed Martin, now work smarter with Corporate Accounts. Save over 36%!
Time Tested Networking Hardware Solutions: 201 - 225 of 839
Hi, 1) I just bought the Cisco 1720 Router from Ebay 2) It has already got the IOS Software 3) My Goal: i) I want to play around with this Router, ii) I want to UNINSTALL and INSTALL back...
I have a number of Dell PowerConnect 3348 switches that I am trying to configure with static IPs for management purposes. I have found the VLan IP address and when I try to change it, I get a ...
I have a PC upstairs, with an external modem hooked to a 4-port Linkisys Router, which I run my laptop downstairs off of.  It seems like they used to be about the same speed (connection speed)...
I have to run some ethernet cable a total distance of about 600 feet. So, since there is a limitation with Cat5/6 of about 325 feet per segment, I'm going to run two 300 foot segments and put ...
We have a Linksys RV082 connected to a Business 6mb Cable line.  This cable modem puts up speed of about 6500kbps almost every time if its connected to just a single computer.  When I connect ...
Hi everybody... I'm here 'cause I have a problem with my internet, in my home I have internet with Bellsouth Company and I use a Westell 6100 Modem with an Username and a Password to access...
We purchased a Procurve 2900 about half a year ago. Recently I started checking it for errors as we experience delays at times writing or reading data from the file server ( This office about ...
My company was recently acquired by a third party which is now in the process of reviewing our infrastructure. One of the things they are covering is our existing MAN, so I'd like to get s...
I want to connect a 3COM 4400 Switch to a Cisco 4506 Switch. The Cisco 4506 Switch is going to be the VTP server, and all the other switches are going to be the clients. My question is  how ca...
I understand what a default gateway is. A Default Gateway is essentially the gateway into or out of a network -- and it is used when a station on the network is unable to resolve and route to ...
I need Windows XP drivers for the Cisco Aironet 340 wireless adapter that supports WPA-PSK. I have seen several references in my searching that it does support WPA, but for the life of me, ...
i have windows server 2003 and hp procurve 3500yl as the edge switch, with the procurve switches it has many unmanaged hubs connected, the clients are connected to the unmanaged hubs i dont...
At our "primary" location, our company uses access-control lists on our perimeter Cisco router to reduce all incoming traffic to just the ports required for our DMZ servers.  Inside that we us...
This laptop has Windows Vista Basic as its OS. The wireless network is enabled, and I have a connection with my router and internet.  It is showing that the computer has excellent signal st...
i have cisco catalist switch 2924 and cisco 3524 . which one of these work as layer 3 and layer 2 together based on which ios version. as i am planning to buy a new 3550 switch so want to dec...
I have a Linksys  wireless router and comcast cable for internet.  For some reason my internet stopped working. I went into cmd.exe and did a ipconfig /all I was not getting DNS. I did a power...
Hello, My Desktop's HDD is dead. I have Laptop with windows XP MCE installed. Me and my brother both needs one of them at the same time but as I described my desktop's HDD is dead and I...
How configure redundancy in tow HP 2610 procurve switch? so if one line down the other line should be OK  :) I don't have any vlan , all IP in my network in range all is static IP 172...
I have windows xp and have a wireless network and the front desk computer is wired into the network I changed out the wireless AP unit and everything works except the front desk which is hard ...
How to turnoff debug all output on hyperterminal console. I enabled it on a cat 2950 test switch and now cannot disable it due to continuous scrolling output on the screen. I know one can use ...
Hello- I have a netgear prosafe FVS336G firewall router that I VPN to using the built in web client (accessed via a dyndns updated IP).  When using the web client, I can only access the IPs at...
I'm configuring an ASA firewall that is not connected to the network, and when trying to set the LAN IP address I get the error above.
I have 2 IBM eSeries x235 servers with SCSI HDD. Both machines have QLogic QLA2200 64 bit fibre channel. I want to connect each machine HBA to other HBA to make single point to point N port co...
Hello ! We have a network of about 50 users and many of them use Vmware / Virtual pc so the number of computers that are connected is about 90. How many computers can the Fortigate 60 ha...
I bought a Cisco 871W off newegg for my small business. I figured I'd be able to go to the cisco site and download the latest "firmware" for free. Boy was I wrong! I don't even think the word ...
