Time for your 3rd Quarter Update! Are you in the running for the 6th Annual Expert Awards? Click the link to find out.
Third Quarter Hot Shots
Top 802.11 Wireless Solutions: 1 - 25 of 47
I'm having a problem with a few DELL Latitude D630 laptops connecting to wireless networks which have WPA2 encryption set.  All these computers use an Intel WiFi 4965AGN NIC  and the computers...
In my Cisco 1230 AP, has two radio's (one a band and one b band). Both work fine. Except, that by specification of the radio modules (both) they should be able to handle WPA2 AES encryption. ...
I set up my WNDR3700 Netgear and have it connected to my gigabit iomega home media server and macbook air but I can't seem to get a transfer speed of more then 5 MB/s according to this...
In my organization we've been running Aironet 1100's off of a Dell 3548P which then goes into a Cisco 3750. We're also running multiple user devices off of the Dell switch. One SSID, no VLANs ...
Hi gang!  I have an IBM Lenovo R61E.  After reloading the system and upgrading to Service Pack 3 (Windows XP Pro) I can no longer access the wireless internet at my house.  I went into the Thi...
I recently bought a Buffalo Nfiniti" Wireless-N Ultra Compact USB 2.0 Adapter WLI-UC-GN. This is a small USB adapter that is to allow me to connect (Wi-Fi) using the 802.11n protocol. I bought...
Hi I have just Conducted  a clean installation of Vista sp1 on a new hard drive in a Compaq presaio F600 laptop, all drivers have installed correctly except the wireless card which is made by...
I have a Windows Vista Laptop that can see both my secured and another unsecured wireless network, but the machine will not connect to either.  On the secured network, it will not even ask me ...
We have some wireless computers set up on mobile carts in long building with an access point on each end. The machines will connect to their nearest access point ok and the signal is strong. ...
I have a linksys WRT320N wireless router and a macbook air with wirelessn and I am measuring my net traffic with an app called net monitor right now it says I am only getting around 2.1...
I have my Macbook connected to a wireless router but a Vista machine I'd like to connect has issues.  In Vista, it sees the wireless router, tries to connect and then says it was unsuccessful....
Hello EE.  Im trying to do a reconfiguration of our wireless infrastructure and am having some difficulties.  I have 4 Cisco Aironet 1240AGs, and am trying to configure them with two SSIDs.  ...
This question is pertaining to the solution: http://www.experts-exchange.com/Networking/Protocols/DHCP/Q_24261848.html#a24007688 The network configuration has since been changed and the ...
I've learned that runnng a wireless AP with 802.11n on 2.4GHz typically uses all three non-overlapping channels.  Two channels would be bonded for 802.11n MIMO while the third would be availab...
I just recently switched from a Dell Inspiron 9300 with an Intel Wireless BG built in adapter to a Dell Vostro 1720 with a Dell Wireless 1510 Wireless-N WLAN Mini-Card The home network runs...
I have searched but can not find any documentation that defines exactly what the Cisco Wireless Compatible Extensions program is and what network areas and features it covers?
I have one Ubiquiti bullet and 3 Ubiquiti Power Station two units.  They all use AirOS.  I want to set up the bullet as an access point and the three power stations as clients.  I have T1 with...
I have a Linksys Wireless Router that will not accept the passphrase however when I type the encrypted key in it accepts and connects.  Has anyone ever seen this ?  I
I have been asked to install a wireless access point in a boardroom to facilitate internet access for clients coming in.  I have secured the actual access point as best as is possible, but I h...
This system worked ok on XP Pro, swapped out HD and upgraded to W7, a task in itself.  Now that W7 seems to be functional, how can I get a wireless connection.  It does not recognize there is ...
Greetgs, I currently have a Linksys WRT54G wireless router, and I would like to expand the signal by adding another wireless router on the other side of my house.  I'd like the SSID to be t...
I have dual T1 circuits coming into my building. I want a router that can handle both of them (dual wic cards) but i want to configure the router so that each T1 is independant OR so that each...
Hello there, This question is in general: Is there a way you can reduce the wireless operating range from an access point? For example I am able to connect to my wireless access point...
trying to connect Wireless Router through PC having VISTA, not able to browse admin page
Is it possible to configure an Aeronet 1200 to use WPA2 (without a RADIUS server)? I have logged into the web interface and in order to use WPA2 it wants a RADIUS server, and it's not obvious...
