Linksys Wireless b mode? or g mode?
Asked by: xtopher
I have a new Compaq Presario V6000 with a Dell Wireless 1390 WLAN Mini PCI card in it.  It came from the store with Microsoft Vista loaded on it.  The computer detected my Linksys wireless network system and operated in the "g" mode perfectly.  I cleaned off the hard drive and installed Ubuntu 7.04 "Feisty Fawn" and it took some work, but I did get the wireless up and running.  Here's the problem.  When I connect to the network via Ethernet cable, I get lightning speed.  But when I use the wireless, I only get about 25 kbps.  Real slow.  I looked at some hardware settings and saw that in was operating at 11mbps.  Someone told me that was the "b" mode of my wireless.  How do I get my wireless card to work in the "g" mode?  Faster in other words?
Chris
2007-04-08 at 13:49:36ID22498826
mode
wireless
b
g
linksys
802.11 Wireless Access Points
Ubuntu
Wireless Network Cards & Adapters
  1. WLAN
    Hi, I have installed RedHat 8 (I believe kernel version: 2.4.18-14) onto my laptop. For this laptop I bought a pcmcia network pc card (LinkSys WPC11 v3) and have a LinkSys Wireless router. I am having trouble getting this network to work The router works correctly for all m...
  2. Wireless Network Connection (linksys)
    Hi, I have HP laptop with WLAN 54g W450 adapter. I have been using the laptop for 2-3 months without any wireless connectivity to the Internet. Yesterday, when I booted the laptop, a message appeared in the task bar that Wireless Network Connection (linksys) is active. I was...
  3. Linksys devices
    How many wireless devices can cannect to a single linksys router or access point?
  4. Linksys Wireless - Arghh!
    I just removed Malware and viruses from my 98 box. I have a Linksys wireless and a hardwired NIC. The NIC works flawlessly on the network and internet, but the wireless will not connect. I have uninstalled - reinstalled all network components. Still no go. TCP/IP re-install. ...
  5. What does the Act and Link lights for WLAN signify for Link…
    Hi Everyone: I am in the process of trying to learn as much as possible about my new Linksys 802.11-g Wireless Broadband Router (Model WRT54G). On the front panel, there is an area labeled WLAN. Above it, there are two lights. Once is labeled Act which is off and o...
by: PUNKYPosted on 2007-04-08 at 14:00:57ID: 18873367
Someone has told you wrong, even b mode you could get faster, not slower than dial-up modem in history. Please see the link http://www.microsoft.com/athome/moredone/wirelesstips.mspx
by: xtopherPosted on 2007-04-08 at 15:36:45ID: 18873579
I never said it was slower or faster than dial up.  The wireless is much slower than when I'm pluged up to the Ethernet  cable.  My question is can I change the mode that the wireless is operating in (b or g).  Don't forget, I'm not using Microsoft, I'm using Linux with the Ubuntu distro.
Chris
by: PUNKYPosted on 2007-04-08 at 17:30:16ID: 18873792
What is linksys router brand?
by: xtopherPosted on 2007-04-08 at 19:45:55ID: 18874069
WRT54G  with speed boost Firmware ver. 3.03.6
