Cisco 1240AG Access Point ethernet port problem
Asked by bkesting in 802.11 Wireless Access Points
Tags: cisco, 1240ag, access, point, ethernet
I have a Cisco Aironet 1240AG Access Point.  I received it a few days ago and configured it and it was working properly.  Then all of a sudden I could no longer browse past the AP with a notebook.  I could not access it via IP, so I hooked up a console cable and watched it boot.  I then saw the following message during boot:
The system has been encountered an error initializing ethernet port.  You may need to check hardware.  The system is ignoring the error and continuing to boot.  If you interrupt the boot process, the following commands will reinitialize ethernet, tftp, and finish booting the operating system software:
ether_init
tftp_init
boot
The AP then continues on with the boot process, but the ethernet port appears to be dead.  I have reset the AP to its original, factory state and that has not helped.  Has anyone else encountered this and if so, how can it be remedied?
Thanks.
[+][-]05/14/07 03:22 PM, ID: 19088949Accepted Solution
Zone: 802.11 Wireless Access Points
Solution Provided By: nerdzoll
Solution Grade: B
[+][-]06/18/07 04:17 AM, ID: 19305999Expert Comment
[+][-]06/18/07 09:10 AM, ID: 19308318Author Comment
20091111-EE-VQP-92
