Needing Windows XP Pro SP2 Drivers for Linksys Wireless G 2.4 GHz Network Adapter (direct download link if possible)
Asked by: GMartin
Hi Everyone:
       Today, I was able to successfully get my Linksys 802.11g router working fine.  However, I was unable to get the Linksys Wireless G 2.4GHz network adapter to work because XP Pro SP2 could not find native or built in drivers for this device.  Consequently, the operating system put it within a category called Other Devices.  With these points in mind, I am need any direct download link for XP Pro SP2 drivers for the Linksys Wireless G Network Adapter.
        Any help regarding this question will be appreciated.  I look forward to hearing from everyone regarding this post.
        Thank you
        George
2007-08-20 at 13:23:35ID22775121
linksys
driver
download
wireless
ghz
802.11 Wireless Access Points
Wireless Network Cards & Adapters
  1. Linksys Wireless b Connection problem
    Good morning, I have a Linksys wireless router that is working with a variety of laptops and wireless cards at our company. It is a Linksys 2.4 ghz BEFW11S4 Wireless B router. We have a new HP Laptop with a Broadcom 54g maxperformance 802.11g internal network card that ...
  2. linksys wireless
    i have a linksys wireless n router that works great but in teh room down the hallway the signals goes to nothing or one bar. what can I do to get the signal to work better down there
  3. Orinoco wireless card issue w/ Linksys 2.4 ghz router
    Hi, I have a Orinoco 11 Mbit/s silver wireless card and trying to use it with Linksys 2.4 ghz wireless router, but in vain. Can someone please tell me what the issue is? Are there any compatibility contraints? Wired configuration works fine, but it's just the wireless conf...
by: GMartinPosted on 2007-08-20 at 13:44:40ID: 19733603
Hi
        Please accept my apologies, but, I forgot to include the model number of the Linksys G Wireless Adapter.  It is XS-WUSB54G.
         Thank you.
         George
by: PUNKYPosted on 2007-08-20 at 19:03:31ID: 19735057
by: GMartinPosted on 2007-08-26 at 12:27:02ID: 19771906
Hi There:
        Thank you so much for the resourceful link supplied.  It was very easy to locate the necessary drivers for this Linksys Wireless G Network Adapter.  Unfortunately, this device is physically defective because it constantly looses power on any pc within a few seconds.  I am not sure what cause the power light to go out within a few seconds of being interfaced via USB, but, I am sure there is something physically wrong with the adapter.  In any case, the company, Gearxs.com has been advised of this situation.  A warranty replacement will most likely be the final outcome in this situation.
         Once again, many thanks for a job so well done..  As always, your suggestions are appreciated.
         George
