HP laptop drivers/Wireless
Asked by: lazik
Hello
I have re-installed XP pro sp2 on a HP zv5430us laptop and I am unable to access the wireless network that I was on before this, in Device MAnager I have the yellow ! under Other devices: BAse systems device AND SM Bus controller also, on the bottom left I have teh icon corcled out in red that says Wireless network interface disabled.
I have the WZC disabled in services and still no luck...Any ideas??
Afetr the fresh install I d/l all the drivers for this laptop at HP's website. Is there something I'm missing or need to enable/disable??
2007-11-14 at 04:40:50ID22959709
hp
laptop
drivers
wireless
802.11 Wireless Access Points
General Laptop
Windows XP Operating System
  1. SM Bus Controller?  What is that?
    I am rebuilding a HP nx9110 notebook with XP Pro. Device Manager shows Other Devices "SM BUS CONTROLLER" with the yellow exclamation point. I have no idea what this is? I searched HP's website under drivers/downloads and could not come up with anything. I have t...
  2. wireless hp printer configration
    Dear experts, we are going to purchased a hp wireless printer, i have never configured a wireless printer kindly guide me through the steps that how we configure wireless printer wit xp pro and vista bussiness edition. regards
  3. SM Bus Controller missing driver from HP D325
    I have re-installed WinXP PRO and all the drivers are ok except I have a yellow exclamation mark next to SM Bus Controller. I am using a HP D325. Any help would be great. Thanx
  4. Hp wireless will not turn on
    Hi people, I have this really annoying problem with a Hp laptop. I press the wireless button on the laptop no light comes on, and it says WLAN off, I press it again and it says disabled. It just wont turn on. I have went into the BIOS and all WLAN functions are enabled, have ...
by: ibu1Posted on 2007-11-14 at 05:44:40ID: 20279724
by: The_WarlockPosted on 2007-11-14 at 07:35:19ID: 20280737
Download the Chipset latest drivers for your motherboard.
by: lazikPosted on 2007-11-14 at 08:25:21ID: 20281189
ibu1- I have been to this link and d/l all the drivers that I thought were obvious. please let me know if there is a specific one.
The Warlock- How do I verify the type/make of my mobo?
Thank you both thus far.
by: lbertaccoPosted on 2007-11-14 at 08:44:54ID: 20281382
First of all you should find out which WLAN adapter you have. This laptop can either have an
"HP WLAN W400 or W500" based on the atheros  chipset or a Broadcom Wlan adapter.
How do you find out? it depends. Is it written on some label maybe beneath the laptop, or in the system specification sheet. Or maybe you have an HP utiliy reporting it. Or maybe even in the bios or the bios startup screen (you might have to rpess esc or Fsomething when you power up to see system info).
Remove any wireless driver you have already installed. Reboot. Then yf you have the HP/Atheros, install these 2 drivers:
1) HP WLAN W400-W500 Driver for Windows 2000/XP 05-2006 4.00 B
2) HP WLAN W400-W500 Atheros Client Utility  04-2006 4.00 B
If you have the broadcom, install these:
1) Broadcom WLAN Network Adapters Driver 06-2005 4.00 C
2) Broadcom WLAN Network Adapters User Interface  06-2005 4.00 C
by: lazikPosted on 2007-11-15 at 04:43:33ID: 31409170
Great info everyone.
by: ibu1Posted on 2007-11-17 at 00:32:48ID: 20303714
hey Lazik !!!
Nothing for me for providing the download link :)
by: lazikPosted on 2007-11-17 at 01:01:57ID: 20303761
ibu1
Although I appreciate your assistance however, as stated in my initial post.....After the fresh install I d/l all the drivers for this laptop at HP's website. Is there something I'm missing or need to enable/disable??
...........I already located that site
 .....................................................Thanks again
by: ibu1Posted on 2007-11-17 at 21:12:05ID: 20306566
My pleasure
