Thanks for the help! No new cards or devices. It is the only thing on IRQ11. I did uninstall the card in Device Manager and the software in Control Panel-Add/Remove Programs.
Tonight, I disabled the card and the computer has been fine all night.
I have tested the memory for almost 21 hours with Microsoft Memory Diagnostic Test (it passed) and taken the 2 memory boards out one at a time - no help.
Main Topics
Browse All Topics
by: JJB-ZenfulPosted on 2007-11-28 at 18:25:28ID: 20370871
Have you installed any new cards or devices that may be causing an IRQ conflict which in turn is causing a "BSOD"?
Before reinstalling the driver and software for the card did you uninstall the driver for the device to make sure its completely removed before the re-installation?
