There is no corelation between the modulation scheme and radio speed. The "rule" of 1/6/11 comes from overlapping channels, which is the modulation scheme. Bandwidth refers to how much data is sent over the link. Not how much power output it has. There is a corelation between power usage of a link and interference on a channel.
In a large room, auditorium - non-repeating, I have set up access points in all four corners. In opposite corners I have two APs on channel six with the power turned down to about 40%. In the other two corners I have them on channels 1 & 11, both on max power. This allows for total coverage of the room. The power and channels have no effect on bandwidth however. The number of simultaneous users do.
I hope I have helped you.
Main Topics
Browse All Topics
by: joopvPosted on 2008-04-21 at 04:46:31ID: 21400560
A small addendum on my own posting:
I realize the the receiver RF front-end or IF bandwidth is probably fixed on the highest speed / widest channel usage, and probably won't be adjusted when using lower wifi speeds.
