jhyiesla,
Thank you for the reply. The computer was bought out from my employer when I retired and I hae no original disks. I do have the Toshiba restore disks, but the hard drive corruption meant restore nad repair install was unwise, so I bit the bullet and sent the computer away for a new hard drive - it came back with just XP Pro, SP3 on it and SOME of the Toshiba Drivers. I had to go to the Toshiba site to get some drivers, but cannot tell from the site (Toshiba support Australia and NZ, downloads, Notebook, Tecra, M3) which download might relate to this "unknown device" problem.
I certainly would not want to wipe the disk again, having spent 3 days getting the computer almost completely back to fully operational,
If you can advise which Toshiba driver (from any Toshiba download site you care to choose) for Tecra M3 and XP might relate to this issue, that might be the best way to resolve the matter.
Thanks again,
Main Topics
Browse All Topics
by: jhyieslaPosted on 2008-06-23 at 04:55:45ID: 21845220
If everything is working, you could probably do that. However, it's nice to have all of those issues resolved just in case...
Do you have access to the original restore CD or drivers disk? If so, running the restore CD might fix those issues, of course it would wipe your disk. With some systems there is an extra drivers disk that has on it all of the drivers for what came with your device. If you don't have it, you might try contacting Toshiba or look on their web site to see if it's available a a download. The path reference to the I/F controller seems to indicate that it is looking for some driver disk; although not sure why adding in the wireless driver would bring up this message..unless the installation of the wireless needs this other file in order to complete the installation properly.
