can I configure my Netgear WGT624 v3 to connect to another Wireless network via wireless?
Asked by: kabaam
I have a wireless router down stairs and one upstairs.  I would like to configue one to connect and share the internet access the other one has.  is that possible? what do I need to do?
thanks,
K
2008-09-19 at 17:57:55ID23747722
802.11 Wireless Access Points
  1. Wireless Router - To accept WAN feed over wireless con…
    Does anyone know if you can get a wireless router that will accept its WAN input from a wireless connection? Basically I have my ASDL modem downstairs, but want to put my router upstairs so that I can connect (Via cable) my PCs and servers etc into it. I don't want to have ...
  2. Netgear USB wireless stick cannot connect to a linksys wir…
    I am setting up a friends new computer. They have a wireless router connected to another computer in their basement. They wanted a wireless connection to the new computer upstairs which is three floors up from the basement. I went ahead and inserted the stick into the new ...
  3. Wireless Bridge using Netgear Wireless Router
    I have a both a Linksys and a Belkin wireless network running. The belkin wireless router is also an ADSL router and is connected to the internet, on the LAN port it is connected to NIC 1 on a server, nic 2 on the server connects to a LAN port on the Linksys router, along wit...
  4. Verizon FiOS extending Wireless across house upstairs, r…
    OK so I am going to try and get a solution to my problem, I will purchase something if needed.... This is my setup right now, I have Verizon FiOS, it came with an actiontech wireless router/modem (MI424WR) which i turned off Wireless but using DHCP and attached to that using...
by: ecsrdPosted on 2008-09-19 at 18:01:46ID: 22527332
Does either router have an option in it to configure it as a wireless bridge?  If so, you can, by configuring it.  If you post which router has the capability, please post its name and its current firmware revision and I'll see if I can find a link with some instructions for it on your behalf.
by: kabaamPosted on 2008-09-19 at 18:31:10ID: 22527467
I have this Netgear WGT624 v3 and the other came from ATT for broadband/TV via a coax input.  I do not know what model it is
by: ecsrdPosted on 2008-09-19 at 18:38:21ID: 22527483
It does not appear that the WGT624 is capable of wireless bridging, so, your best option to do this would be to run a network cable from the downstairs device to the upstairs device - connect them both to eachother via an available LAN port.  Configure the WGT624 to allow wireless clients to access the LAN network.
by: daumanPosted on 2008-09-19 at 19:20:17ID: 22527736
running a wire is usually expensive unless your very handy and it's an easy run.
your best alternative is to buy a gameing adapter.
Linksys sells 2, one is WGA600N which is a wireless N adapter. (this also does wireless G)
the other is a WGA54G which does only wireless G.
What this does is it converts wireless signal and converts it back into a wired signal.
they are easy to configure for your wireless network and will work with encryption and any DHCP you have on your other router.  also they are only around 75.00 and easily purchased from bestbuy or  elsewhere.
by: kabaamPosted on 2008-09-19 at 19:46:32ID: 22527955
cool...thanks folks.
One more question regarding alternatives.  Have you used those 115VAC power outlets for cabled connections?  any good?
thanks,
K
