Thanx for your reply. I'll test this and post the results as soon as possible.
Main Topics
Browse All TopicsHow to enable Packet injection and Monitor mode on Intel PRO/Wireless 3945ABG running on Windows Vista? I have read that this is possible with linux, but can it be done on Windows?
Business Accounts
Answer for Membership
by: Darr247Posted on 2008-10-08 at 08:47:18ID: 22670215
Short answer is no.
toolkit.or g/nst/inde x.html
Depending on the chipset used on the wireless card, it may not be possible at all.
But you can try it with a bootable Live Distribution of Linux without losing Vista (until you're ready [grin]).
I suggest Network Security Toolkit (NST).
http://www.networksecurity
