Firmware reload failed on Proxim AP-700
Asked by gamerchick101 in 802.11 Wireless Access Points, Network Cards & Adapters, Wireless Network Cards & Adapters
Tags: AP-700 Proxim
I have a proxim AP-700 that i just got my hands on it has a amber light on the power side from what i see in the manual this is from when you gold the reload button and it deletes the firmware i have tryed to connect via http to the unit and i cannot so i used scan tool to set the AP to static and tryed that still not luck on connecting but i can see it with scan tool so i set up a TFTP server on my PC and put the new MIB in it and used scan tool to make the AP DL this, my TFTP server shows 100% ok on the DL reset the AP still amber light and no web config i have tryed this 4 times now with no luck and i just tryed it again with CLI not scan tool and same outcome any ideas?
[+][-]03/12/09 08:23 AM, ID: 23869424Expert Comment
[+][-]03/12/09 08:27 AM, ID: 23869492Author Comment
[+][-]08/05/09 12:28 PM, ID: 25027104Accepted Solution
Zones: 802.11 Wireless Access Points, Network Cards & Adapters, Wireless Network Cards & Adapters
Tags: AP-700 Proxim
Solution Provided By: mvalencia2003
Solution Grade: C
