How to connect 2 buildings via wireless
Asked by: menreeq
I need to connect 2 buildings that are 500 yards apart via a wireless solution.  There won't be a lot of traffic going over the link but we will have a couple of users with VOIP phones that will be connecting to the VOIP phone system so the link has to be reliable.  There is line of sight.  What robust outdoor solution can you recommend?  Although it may work, I'm not looking for the residential grade Linksys AP solution.  Thanks in advance.
2009-07-08 at 10:40:28ID24554034
wireless
WIFI
VOIP
802.11 Wireless Access Points
Wireless Local Area Network
Wireless Network Cards & Adapters
  1. Wireless AP Bottleneck?
    How do I determine if the Wireless AP (Specifically the private side) in the attached PDF is a Bottleneck in my network? Assumptions: 1.) All internal connections to the network are gig to the desktop with no complaints (300 plus Network/VOIP users - 10 buildings connected b...
  2. VLAN for Wireless AP from Firewall to AP bypassing Windo…
    Hey folks, I'm new to VLANs but here's what I want to do. I have 4 Linksys SLM2048 Managed Switches that are daisy chained with miniGBICs from building to building. I have our firewall in our main building and I have a Wireless AP in our lobby building that I want to offer G...
by: ThaVWManPosted on 2009-07-08 at 12:14:38ID: 24807143
Here you go.. something like this would work:
http://www.airlinx.com/products.cfm/product/19-182-0.htm
by: ThaVWManPosted on 2009-07-08 at 12:15:31ID: 24807146
Or this company offers products for what you are looking for:
http://www.proxim.com/
by: menreeqPosted on 2009-07-08 at 13:23:17ID: 24807954
thanks, it looks like 3com also has a product:  http://www.3com.com/products/en_US/detail.jsp?tab=features&pathtype=purchase&sku=3CRWEASYA73
what brand would you recommend?
