Wireless Settings
Asked by: jake10
I am setting up a wireless environment for a section of the office that is the reception and staff rest area for staff and guest. I am using a broadband router Linksys WRT160N. The router IP is 192.168.1.1 and DHCP for office machines starts from 192.168.1.21.  The problem is that I get alot of problems of disconnection even if the wireless signal is excellent.  The only option is to switch of the router and reconnect it  back and then it starts working again.  But this prodecure has to be done very morning.  What is a routing table.  Someone told me that I have to setup the routing table.  How is it done.
2009-07-17 at 22:23:09ID24580889
802.11 Wireless Access Points
Wireless Network Cards & Adapters
  1. Linksys Wireless-B Broadband Router
    Hello, I have a question about the abilities of my Linksys Wireless-B Broadband Router. I have set up an IDS (Snort on Linux) which needs to work in a hub environment to capture all the network traffic. The Linux box can see attacks against it no problem but can't see the r...
  2. Connecting Linksys Wireless Access Point to Linksys Wirel…
    I'm planning to get a Linksys Access Point to add on to my existing Linksys-operated network (wireless B network). My current network configuration is an DSL modem connected to Linksys Wireless Broadband Router, and 2 notebooks connected wirelessly to the broadband router. I ...
  3. Wireless-N reception is horrible
    I just got a Linksys wireless-n router (WRT300N) and also a Linksys wireless-n card (WPC300N) for my laptop which runs Windows 2000. Why is the reception so horrible?? I am two rooms away - maybe 30' away! In the same room it has 100% excellent signal strength and is fast....
  4. Guest Wireless Access
    I am trying to configure guest access to the internet without allowing them to connect to any other device on the network. I have a wireless router connected to a port on the core switch. Can I put ACL's in place to allow only the IP's of the wireless clients to only go to th...
by: Sniper98GPosted on 2009-07-18 at 09:51:16ID: 24886586
If you have a single layer two subnet spanning the office you do not need to worry about routing tables. There are several issues that could be causing your problem I would need to know a little bit more about how your network is setup to narrow it down.
Please provide a good description of how this device connects to the rest of your network; what channels you are using what interfaces are connected to what. If you have any other wireless in the area please also provide thier channel information. Any other general info about your network would also be helpful.
by: Darr247Posted on 2009-07-18 at 17:43:39ID: 24887904
Back up the settings on the router. The commands to do that are usually on the Adminstration tab on Linksys routers.
After that do a 'hard' reset on it... instructions here:
http://experts-exchange.com/articles/Hardware/Networking_Hardware/Wireless/Perform-a-30-30-30-reset-on-your-Wireless-Router.html
Then reload the saved settings and see if the wireless is stable.
by: biofishfreakPosted on 2009-07-18 at 23:59:46ID: 24888516
I had a similar problem with that same model router, and a firmware update fixed things.
