Two wireless connections on same DSL line?
Asked by sasllc in 802.11 Wireless Access Points, Wireless Network Cards & Adapters, DSL Lines / Cable Internet
I am trying to help a user with his home wireless connections.  He has DSL, and in his house he has a Linksys 4-port DSL wireless router.  The range isn't great, but it works fine in the house.
On the same property, he also has a cabin 200 yards away, which has the same phone number as the house.  Now and then he will take his router to the cabin and run his laptop wirelessly there with no problem.
Now he would like to have a wireless connection in both buildings at the same time, running on the same DSL phone connection.  In case it matters, he does not care about the wired ports on the router, because everything he does is wireless.
What I'm hoping to do is have a good, strong wireless connection in each building.  I assume it would be difficult to get a good signal in the cabin if all I have is a wireless source in the house, because it's 200 yards away.  And, I thought about using power-line connections with an access point in the cabin, but while theses two buildings do share a phone line, they do not share the same electric circuit.
So....that's why I'm wondering what equipment I would need to set up a wireless connection in both buildings.  TIA
Keywords: Two wireless connections on same DS…
[+][-]08/10/09 07:52 AM, ID: 25060427Accepted Solution
Zones: 802.11 Wireless Access Points, Wireless Network Cards & Adapters, DSL Lines / Cable Internet
Solution Provided By: ElrondCT
Participating Experts: 3
[+][-]08/05/09 07:52 AM, ID: 25024090Assisted Solution
[+][-]08/05/09 08:31 AM, ID: 25024598Author Comment
[+][-]08/07/09 09:24 AM, ID: 25044420Expert Comment
[+][-]08/08/09 08:30 AM, ID: 25050515Assisted Solution
[+][-]08/10/09 06:52 AM, ID: 25059877Author Comment
[+][-]08/10/09 09:58 AM, ID: 25061703Expert Comment
