Configuring multiple SSIDs and VLANs on a Cisco Aironet 1100
Asked by: jhol
In my organization we've been running Aironet 1100's off of a Dell 3548P which then goes into a Cisco 3750. We're also running multiple user devices off of the Dell switch. One SSID, no VLANs set up on the Aironet nor anything but the default on the Dell and Cisco ports.
We're looking to turn on a second SSID that customers can hook up to when they come in and only grant them port 80/443 access to the outside world.
Is it possible to turn multiple SSIDs on without necessarily breaking the other user devices' connections in that Dell? Does no VLAN config on the Aironet really mean VLAN 1? I'm also wondering how I'm going to get DHCP going without allowing the second SSID to talk back to our main DHCP server (a Windows box). Serve it out of the 3750 directly?
2009-08-27 at 14:27:23ID24688234
Wireless
SSID
Cisco
802.11 Wireless Access Points
802.11x
Network Routers
  1. Cisco Aironet - broadcast SSID
    I have a Cisco Aironet 1130 running WPA-PSK with TKIP. A manager would like the SSID to be broadcasted, so that visitors can see that wireless is available. We'll still have to provide them with the Pre-Shared Key to get on. What line do I need to add to do this?
  2. Multiple SSIDS on an Aironet 1130ag DHCP issue.
    We have multiple Cisco Aironet 1130ag access point that we want to run without a controller. We have two SSIDS that need to be broadcast via these APs. The problem is that if a client connects to either SSID, they authenticate with our Radius server properly. But do not rec...
  3. Broadcasat SSID
    I have 4 Cisco Aironet 1240AG Access Points in a site. However, the SSID was set not to broadcast by the installer. I need this to be seen by all wireless networks. But I cannot find the setting(s) to enable this. What and where is this done. I have connected to the web ...
  4. Cisco Aironet 1252AG - multiple SSIDs to same VLAN …
    Hi Experts, We currently have two cheap access points we're trying to consolidate with one Aironet 1252AG. One AP is for our laptop users which authenticates to a Microsoft Radius Server. The other AP is used for our copiers and printers which we're using wireless network ad...
  5. Multiple SSID with VLANs
    Hey guys. I'm pretty new to the concept of VLANs and no matter how much I read, I can't quite grasp it. I have a small problem where I would like to configure a VLAN for best practise and security etc but I'm not sure where to start. I have a busy network with 300+ clients...
  6. Cisco Aironet (1130/1200 Series) Multiple SSID /…
    OK, I asked a similar question recently, but feel I need to better express what I'm trying to do: In an educational environment, we currently have Cisco 3500 series switches, and a mix of 1130 and 1200 series Aironet access points. In the mornings before school, music is pla...
by: mikecrPosted on 2009-08-27 at 21:09:01ID: 25204906
Yes, you will break them temporarily. To do what you want, you will need two vlans configured both on the AP and your core switch as long as the rest of your switches pass tagged packets. In other words, you will need to turn on 802.1q trunking on the switchport that the access point is plugged into and also trunk ports between switches.
You will edit vlan 1, configure it's security, then assign that vlan to your current ESSID if it's not already there. Then you will do the same thing with another vlan so that you can segment the guest traffic. You don't need to assign any security to that vlan but you will need to assign an ESSID to it so the users go out tagged differently so that you can control their traffic.
On your core switch that you trunk back to, configure a layer 3 vlan and apply security for HTTP/HTTPS access.
You can't assign multiple ESSIDs to one vlan, it won't let you. Also you can't create a new ESSID and not give it a vlan. Just remember that you're going to need to have trunking enabled on your switches. It will be configured on the switch ports that plug into each other so that it can carry vlan traffic. VLan tags will be assigned by the access point respective of what vlan a user is on.
If you need help setting it up, let me know and I can give you some example code.
If you have any other questions, please let us know.
by: jholPosted on 2009-08-28 at 06:26:47ID: 25207371
Thanks, that's very helpful. For the HTTP/HTTPS traffic, I can just pass the traffic from the guest SSID's VLAN to the same VLAN on the core switch, then? We're not actually doing anything with VLANs on the secondary switch that the wireless device is plugged into besides just telling it to pass the VLAN data along to the core switch via trunking, correct? And for VLAN 1, we're basically just leaving that alone after specifically assigning it to the existing SSID.
For the DHCP, I'm assuming I should just be able to pass BOOTP between the wireless clients and the server without too much trouble, correct?
Sorry for so many follow-ups. I just want to be clear before I accept the solution.
by: mikecrPosted on 2009-08-28 at 07:36:32ID: 25208092
To answer your first question, yes, you will create the same vlan on your core as you did on your access point. Trunking will get you there. You just need to make sure that the port on the switch that the access points are plugged into are set up for trunking, nothing else needs done to the switch. They'll pass the traffic back to the core where the vlan is configured.
It is probably alread configured for security on vlan1 however if not, you'll need to make sure. Once you assing the vlan to the ESSID, then your security takes effect. So if you have a default configuration on the access point, you shouldn't have to do anything else with it because your security should already be configured correctly. Just look in the web interface at the access points configuration under the ESSID and you should see if vlan1 is assigned. If all is well, just leave it along and move on to configuring the next vlan and ESSID.
As for DHCP, just put a help address on the vlan interface that your using for the guest wireless pointing to your dhcp server so that the guest can get an IP address. When you configure the access list on the interface of the guest vlan only allowing certain traffic, make sure you configure it to pass DHCP/BootP traffic.
by: jholPosted on 2009-08-28 at 07:47:05ID: 25208233
Great, we'll get this implemented and I'll accept after it's all in. Thanks again.
by: mikecrPosted on 2009-08-28 at 08:27:53ID: 25208666
Good luck and if you need help with any configurations, let me know.
by: jholPosted on 2009-08-31 at 11:46:07ID: 25225253
Alright, I have the second SSID turned on and accepting connections, but it doesn't seem to be passing the DHCP requests. I've gone back down to the bare setup, no access lists on the port, no security just to be sure and it still won't give guests their IP addresses. I've tried helper addresses on every interface I can think of, still no dice. Here are a few relevent snippets from our devices.
Access point:
interface Dot11Radio0.10
 encapsulation dot1Q 10
 ip helper-address x.x.x.x
 no ip route-cache
 bridge-group 10
 bridge-group 10 subscriber-loop-control
 bridge-group 10 block-unknown-source
 no bridge-group 10 source-learning
 no bridge-group 10 unicast-flooding
 bridge-group 10 spanning-disabled
interface FastEthernet0.10
 no ip route-cache
 bridge-group 10
 no ip address
 no ip route-cache
 mbssid
Dell PoE Switch, Aironets connect in here:
interface range ethernet e(19,21)
switchport mode trunk
dot1x system-auth-control
dot1x guest-vlan enable
Cisco Catalyst, core device:
interface GigabitEthernet1/0/10
 description Dell 3548P
 switchport trunk encapsulation dot1q
interface Vlan10
 description Guest Wireless
 no ip address
 ip helper-address 10.1.13.251
by: jholPosted on 2009-08-31 at 13:17:32ID: 25226059
I've been looking around at other people's examples on the web quite a bit and I'm leaning towards the PowerConnect's trunking being the problem. Could be wrong, but that's my guess. I get the feeling it's not allowing VLAN 10's traffic over to the Cisco properly. Not sure what's missing, though.
by: mikecrPosted on 2009-08-31 at 15:36:26ID: 25227149
Maybe, maybe not. You don't need to put helper addresses on ANY of the access points interfaces. The access point bridges (trunks) to the switch to VLAN 10, so that's where the helper address should be. It should be a routable vlan with an IP address on it on the switch and should have the helper address on it configured to point to your DHCP server.
by: jholPosted on 2009-09-01 at 09:08:37ID: 25233030
So right now on my core switch I have a VLAN 10 created with 10.1.17.1 assigned, which I want to be the gateway for this guest DHCP pool. Right now the VLAN isn't assigned to any ports, which I assume it doesn't need to be, correct? I have the 10.1.17.0 scope set up alongside our old scopes on the Windows DHCP server.
Catalyst:
interface Vlan10
ip address 10.1.17.1 255.255.255.0
Trunking is still set up on the PowerConnect just like earlier. The original SSID is still handing out addressses from the 10.1.13.0 range, our internal range, but no luck yet with the guest access. Any other ideas?
by: mikecrPosted on 2009-09-01 at 13:26:20ID: 25235635
Do a "show int' on the vlan on the catalyst and a "show run int" on the vlan and post them here.
by: jholPosted on 2009-09-01 at 13:45:40ID: 25235831
Here you go.
CORESW#sh int vlan10
Vlan10 is down, line protocol is down
  Hardware is EtherSVI, address is 0023.0533.c046 (bia 0023.0533.c046)
  Description: Guest Wireless
  Internet address is 10.1.17.1/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 1/255
  Encapsulation ARPA, loopback not set
  ARP type: ARPA, ARP Timeout 04:00:00
  Last input never, output never, output hang never
  Last clearing of "show interface" counters never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 0 bits/sec, 0 packets/sec
  5 minute output rate 0 bits/sec, 0 packets/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 interface resets
     0 output buffer failures, 0 output buffers swapped out
CORESW#sh run int vlan10
Building configuration...
Current configuration : 119 bytes
interface Vlan10
end
by: mikecrPosted on 2009-09-01 at 17:28:53ID: 25237356
Do a "no shut" on the vlan10 interface. Plug something into it like a loopback plug or laptop, assign its port to that vlan and get the interface to come up, that's why your IP helper address is not working. Normally when you create a vlan on a 3750 it comes up/udown even though nothing is plugged into it, however you may be running an older IOS.
