Cisco AP WPA2 security now available
Asked by haik0315 in 802.11 Wireless Access Points
Tags: Cisco
In my Cisco 1230 AP, has two radio's (one a band and one b band). Both work fine.
Except, that by specification of the radio modules (both) they should be able to handle WPA2 AES encryption.
In the configuration the highest I can select is WPA.
How can I enable and where, the WPA 2 AES function? Does it has to do with the system software?
Technical details:
Product/Model Number:          AIR-AP1230B-A-K9
System Software Version:         12.3(8)JEA1
Radio: b-band:       Radio 350 Series Firmware 6.00.1
Radio a-band:        Radio AIR-RM20A  Firmware: 6.00.1
[+][-]08/30/09 06:53 AM, ID: 25217667Expert Comment
[+][-]08/30/09 09:09 AM, ID: 25218129Author Comment
[+][-]08/30/09 11:05 AM, ID: 25218535Assisted Solution
[+][-]08/30/09 12:19 PM, ID: 25218848Author Comment
[+][-]08/30/09 01:28 PM, ID: 25219173Expert Comment
[+][-]08/30/09 02:30 PM, ID: 25219477Author Comment
[+][-]08/30/09 02:34 PM, ID: 25219498Expert Comment
[+][-]08/30/09 02:41 PM, ID: 25219530Author Comment
[+][-]08/30/09 02:49 PM, ID: 25219561Author Comment
[+][-]08/30/09 03:09 PM, ID: 25219624Accepted Solution
Zone: 802.11 Wireless Access Points
Tags: Cisco
Solution Provided By: haik0315
