slow linksys 320N wireless N traffic
Asked by: BTMExpert
I have a linksys WRT320N wireless router
and a macbook air with wirelessn
and I am measuring my net traffic with an app called net monitor
right now it says I am only getting around 2.1 MBs
but from the test I see run on this site
http://www.smallnetbuilder.com/content/view/30795/96/1/1/
it says the router should do around 145 Mbs or 18MBs
but I am only getting 2MBs when doing a transfer with my Gigabit NAS that is hooked directly to the router
what can I do to get this up to speed
2009-10-03 at 12:59:28ID24782800
802.11 Wireless Access Points
Network Routers
Apple Networking
  1. Linksys Gigabit Switch Too Slow
    I just installed a Linksys gigabit switch (model EG008W) and two Linksys gigbit network cards (model EG1032). To test the speed, I started copying files from one PC to the other; the speed seemed slow so I looked at the network performance in the task manager. The network uti...
  2. Linksys devices
    How many wireless devices can cannect to a single linksys router or access point?
  3. linksys wireless
    i have a linksys wireless n router that works great but in teh room down the hallway the signals goes to nothing or one bar. what can I do to get the signal to work better down there
by: MagicFarmerPosted on 2009-10-03 at 13:03:27ID: 25486792
Have you manually upgraded all the firmware on your router?
by: wizzardofozPosted on 2009-10-03 at 13:05:11ID: 25486800
The question is what the speed of the NAS is. Cheaper NAS's will not be fast though 2MB/s seems a little on the slow side. Can you specify your NAS model as well.
by: BTMExpertPosted on 2009-10-03 at 13:11:31ID: 25486832
its a Iomega Home Media Drive
by: Darr247Posted on 2009-10-05 at 12:43:54ID: 25498856
The problem is, http://www.smallnetbuilder.com/myincludes/image_page.php?/images/stories/wireless/linksys_wrt320n/linksys_wrt320n_router_throughput.jpg does not tell which band he's using.  I bet it's 5GHz, since he mentions using an Intel card - Intel, Apple and Cisco do not support wide channels in the 2.4GHz band with 802.11n.
Since you have an Apple device in the mix, see what results you get by switching to 5GHz.
by: wizzardofozPosted on 2009-10-05 at 20:42:10ID: 25501735
Dual band or not, the speed he is getting is too low for the network to be the bottleneck unless there are adverse wireless conditions. We can eliminate a slow NAS by checking the speed of the transfer over ethernet preferably for the same dataset.
Then it would be helpful to look at the wireless conditions. On windows i would recommend Inssider from http://www.metageek.net/products/inssider but they dont have a Mac version. But basically you are looking for other interfering signals and your signal strength.
My bet is on the NAS.
by: BTMExpertPosted on 2009-10-05 at 20:42:42ID: 25501736
ok ran the tests and at 2.4ghz I am getting around 2MB/s
and in the 5ghz range with it set to N only I am getting around 5MB/s
so it does make a difference but still no where at the speed it should be
any thing else I can do to diagnose the situation?
by: wizzardofozPosted on 2009-10-05 at 20:50:35ID: 25501766
Whats the speed over Ethernet?
by: BTMExpertPosted on 2009-10-05 at 20:52:56ID: 25501779
hmm just did a test and plugged directly into the router with a ethernet cable and tried to transfer a file and got 32MB/s which makes me think it isn't the NAS
by: wizzardofozPosted on 2009-10-05 at 20:57:47ID: 25501792
ah well I was wrong. Now we need to look at the router. Can you try turning off the SPI firewall and all the other bells and whistles you find in the router setup and trying again.
Looking at your above can you for completeness check the speed of the same file over wireless.
by: BTMExpertPosted on 2009-10-05 at 21:35:49ID: 25501922
What do you mean by SPI firewall?  Do you mean the wireless security?
by: BTMExpertPosted on 2009-10-05 at 21:37:35ID: 25501931
found it
by: BTMExpertPosted on 2009-10-05 at 21:45:15ID: 25501956
ok with SPI turned off I am getting around 4.5MB/s
and I am transferring the same file each time
by: wizzardofozPosted on 2009-10-05 at 22:33:39ID: 25502079
Are there a lot of other wifi's in your area. Are they on the same channel as your router? Does putting the laptop close to the router help.
This is not the most scientific measurement but alas I don't know the relevant Mac tools.
by: BTMExpertPosted on 2009-10-06 at 04:15:54ID: 25503719
Yes it seems like there are around 7 different wifis nearby. All of the tests I have been doing are about 15 feet from the router with line of sight.
by: BTMExpertPosted on 2009-10-07 at 21:26:23ID: 25522332
still just getting extremely poor throughput on this router maybe I should flash it with dd-wrt
