What kind of setup do I need?
Asked by: level9tech
I have a building with 2 floors an around 20,000 square feet. I am looking to provide free Wi-Fi. I also want to have content filtering, such as no torrents. I would also like some type of authentication such as what is used at Starbucks. So main things I need are:
1)How many Access Points do I need/what kind?
2)What kind of software/hardware is required for content filtering and authentication.
Thanks.
2009-11-04 at 09:32:58ID24871669
Access Points
802.11 Wireless Access Points
Wireless Network Access Points
  1. Setting up a Wi-Fi cafe
    Hi! I would like to find a website or a book that explains all the details for setting up Wi-Fi(802.11b) for a cafe. I have seen alot of doc and articles for setting up a Wi-Fi(for SOHO or home), but all of them is very basic and did not actually answer my question like - 1...
  2. Linux & Wi-Fi
    Does anybody have experience with installing Wi-Fi on a Linux box? And specifically, setting up "point-to-point" connections with it? Would like to install a Wi-Fi card on a Linux box, and do some point-to-point admin if possible, but not sure where to start. Sug...
  3. Wi Fi  voip
    Hi ; I would like to know about the wi fi voip . 1. What devices or brand do u guys know for the wi -fi ( i heard about a sip phones wi -fi) 2. Does this work with antennas ? how far is the coverage 8 i heard about 15km i dont remember the brand 3. What company is a...
  4. Wi-Fi Broadband Project.
    Hello, I am in my final year studying Business IT at uni and am researching a number of technologies and ideas on which I could base my final year project. The project is concerned with finding an IT opportunity and developing the idea to a level where it could become market...
  5. wi-fi and lan
    i have a wired networked with cat 5 cables and 3 com switch and i have a wi-fi networked by a wireless router attached to the 3 com switch,both networks are in the same area, and every network has it's own setup and ip configuration, my question is how i can let the wi-fi use...
by: level9techPosted on 2009-11-04 at 11:39:26ID: 25743030
Anyone?
by: dkwiebePosted on 2009-11-04 at 21:00:25ID: 25746889
I would use Ubiquiti Picostation 2s.  How many you need really depends on the layout of the building but these are very powerful and sensitive devices so you will get excellent coverage.  There is a wealth of different applications you can use to control access to the wireless network.  The last hotspot we built we used Monowall as a hotspot controller.  The next one is going to be a PFSense box using a 3rd party hosted billing solution.  I'd also recommend checking out the Endian product line for hotspots.
by: level9techPosted on 2009-11-05 at 13:10:03ID: 25754061
How many AP would you recommend starting off with? Its a 2 level apartment complex.
by: dkwiebePosted on 2009-11-05 at 13:43:17ID: 25754372
I'd start off with 2 access points.  Concrete walls are bad for wireless signal so it depends on your firewalls.
by: level9techPosted on 2009-11-05 at 15:16:56ID: 25755170
what kind of access points would you recommend?
by: dkwiebePosted on 2009-11-05 at 17:05:35ID: 25755861
We've been using PicoStations by ubiquiti.  I know some people would recommend Cisco but we've had excellent results with Ubiquiti products for a fraction of the price.  The PicoStations are a nice little AP with omni antenna.  If you want to use your own antenna then you could hook it up to a NanoStation.
