Does clarkconnect also support content filtering? If not, any suggestions of what to use.
Main Topics
Browse All TopicsI have a building with 2 floors an around 20,000 square feet. I am looking to provide free Wi-Fi. I also want to have content filtering, such as no torrents. I would also like some type of authentication such as what is used at Starbucks. So main things I need are:
1)How many Access Points do I need/what kind?
2)What kind of software/hardware is required for content filtering and authentication.
Thanks.
There is, see if this meets your needs:
http://www.clarkconnect.co
Business Accounts
Answer for Membership
by: PlantwizPosted on 2009-11-04 at 14:32:33ID: 25744783
As far as how many access points needed...well, that depends on what types of interference you have. What are the wall made of? Lots of metal around? other wireless etc.. to interfer? So, if you have those obstacles. You'll want more AP.
As far as filtering, you could look at ClarkConnect and set up some gateway filtering.
