Wimax non line of sight  does it work
Asked by pawankk in 802.16 Broadband Wireless Access, 802.11 Wireless Access Points, DSL Lines / Cable Internet
Tags: Brovis Radwin Motorolla
Dear buddies,
1. Wireless wimax or wifi  (Non lign of sight) setup any device which can work on non line of sight for a range of  20-30 km  at  2.4 or  5.8  mhz
many have adviced me  and datasheets  attached for technical specification
1. senao  http://www.senao.in/soc8610ext.html
          Wireless Dual Band Outdoor Client Bridge/ AP/ WDS | Datasheet  SOC 8610 EXT
          2.4 GHz IEEE802.11b/g Standard and 5 GHz IEEE 802.11a standard compliant
           High- Speed data rate Up to 54 Mbps
           WPA/WPA2/WPA-PSK (TKIP/AES) support
          Power over-Ethernet spport (IEEE 802.3af compliant)
         High output power-
                  upto 20 dBm (100 mw)(ETSI)
                 upto 26 dBm (400 mw)(FCC)
          MAC address filtering
          Web/Telnet remote management
           Watertight and Weatherproof
2. brovis :- http://www.brovis.com/downloads/AS1200%20MSH.pdf
         AirStation 1000 Broadband Wireless Access (BWA) concentrator is a high-performance, base-
         station system configurable to operate as a Point-to-Multipoint (P-MP) system or Point-to-Point
          system (P-P) for outdoor wireless applications. It uses BroVis Wireless Networks innovative True
           EXOR" (Extended Outdoor Range) technology to provide plug and play NLOS (Non Line of Sight)
          capabilities in rough terrains.
3. radwin  :- http://www.radwin.com/UserFiles/File/RadWin/Brochures/ProductOverview_En.pdf
             The IDU provides the user with TDM and Ethernet ports to connect to the link on both sides. The
              IDU is available in a number of configurations:
             1. IDU-E  a half 19'  1U plastic unit, providing one Ethernet port and 0-2 E1/T1 interfaces. The
                 IDU-E complies with FCC/ETSI/CSA standards and can be powered via 110-240VAC or -
                 48VDC.
             2. IDU-C  a 19'  1U metal unit, providing two Ethernet ports and 4xE1/T1 interfaces. The IDU-E
               complies with FCC/ETSI/CSA standards and can be powered via redundant 110-240VAC, -
               48VDC and 24VDC.
            3. IDU-R  a half 19'  1U plastic unit for 1 x T1/E1 backup, providing 2 Ethernet ports and an
                external alarms interface. IDU-R complies with FCC/ETSI/CSA standards and can be powered
                via 110-240VAC or -20--60VDC.
                IDU-R is used for automatic backup of leased lines. IDU-R monitors the status of leased lines,
               and in the event of a failure automatically switches to the radio link.
              The Outdoor Unit (ODU)
                  The ODU can be pole or wall mounted. It includes all radio components and connects to the
                  IDU via a CAT5 cable. The different ODUs of the WinLink 1000 product family are available at
                  various frequency bands and currently include the following options:
                   2.3 GHz
                    2.4  GHz (ETSI or FCC)
                    2.5 GHz (FCC)
                    4.9 GHz (FCC)
                   5.3 GHz (FCC)
                   5.4 GHz (ETSI or FCC)
                   5.8 GHz (FCC)
                  The ODU comes in two different form factors:
                          ODU with integrated 1ft flat panel antenna (available for most frequencies).
                         ODU with a connector for an external antenna
4. cannopy motorola  http://motorola.canopywireless.com/products/specs/make.php?recID=1506
Point to Multipoint > 5.7 GHz Advantage AP UK AES
 Canopy Part Number 5751APC
Description 5.7 GHz Advantage AP UK AES
Signaling Rate 20 Mbps Maximum
Typical LOS Range Adjustable to 2 Mi
Typical Aggregate Useful Throughput 14 Mbps Maximum
Frequency range of band ISM 5725-5850 MHz
Non-overlapping Channels 6
Channel Width 20 MHz
Modulation Type High Index 2-level and 4-level Frequency Shift Keying (FSK) optimized for interference rejection
Channel Spacing configurable on 5 MHz increments
Encryption AES capable
Latency 5 - 7 msec
Carrier to Interference ratio (C/I) ~3dB @ 10 Mbps, ~10dB @ 20 Mbps at -65dBm
Nominal Receiver Sensitivity (dbm typical) -86 dBm@ 10 Mbps, -79dBm @ 20 Mbps
EIRP (dBm) Adjustable
Equivalent Isotropic Radiated Power (EIRP) Adjustable
DC Power (typical) 0.3 A @ 24 VDC= 7.2 W
Mean Time Between Failure (MTBF) 40 yr
Temperature -40° C to +55° C (-40° F to +131° F)
Wind Survival 190 km/hr (118 miles/hr)
Dimensions 11.75 in H x 3.4 in W x 3.4 in D (29.9 cm H x 8.6 cm W x 8.6 cm D)
Weight .45 kg (1 lb)
Access Method Time Division Duplexing/Time Division Multiple Access (TDD/TDMA)
Interface 10/100 Base T, half/full duplex. Rate auto negotiated (802.3 compliant)
Protocols Used IPV4, UDP, TCP, ICMP, Telnet, HTTP, FTP, SNMP
Network Management HTTP, TELNET, FTP, SNMP Version 2c
FCC ID ABZ89FC5804
Industry Canada Certification Number 109W-5700
waiting for  all of your advice and suggestions and views regardign products
[+][-]03/03/08 07:15 PM, ID: 21038007Administrative Comment
[+][-]03/03/08 08:36 PM, ID: 21038366Expert Comment
[+][-]03/04/08 12:06 AM, ID: 21039070Author Comment
[+][-]07/16/09 12:31 PM, ID: 24872890Expert Comment
20091111-EE-VQP-89 / EE_QW_2_20070628
