Wireless IP camara settings
Asked by jayeshputhoor in 802.11 Wireless Access Points, IT Administration, 802.16 Broadband Wireless Access
Tags: Linksys Camara
Hi, My am setting up linksys camara in my office, Everything setup i can access the camaras from local ip with wire and without wire. now my task is to configure Remote access in the camara. I did all the necessory steps. but still i am not able to connect the camara.Please look the steps i did.
1. Created a account in dyndns.org, and enterd the domain name and username in the linksys router.
2.Went to Linksys cam, went to option set upnp enabled and http enabled port number to 1024.
3.In the router i forworded port 1024 ( single port forwording ) to the ip address of the camara
4.Already assigned static ip to Camara.
5.I checked diffrnt port, nothing happend.
6. i am able to ping from outside.
7.So i believe port forwording is not happening in the router
8. i thought to check port forwording in the router, so i opend 3389 port to one computer ip address. it worked , i could access the pc from remote location.
9.I went linksys website and checked all the details i havent get any clue.
Please help me to sort out the problem, Its V-urgent actually
Thank you very much
Jayesh
[+][-]10/31/09 05:18 AM, ID: 25709411Accepted Solution
Zones: 802.11 Wireless Access Points, IT Administration, 802.16 Broadband Wireless Access
Solution Provided By: Darr247
Solution Grade: B
[+][-]10/07/09 01:57 PM, ID: 25519974Expert Comment
[+][-]10/07/09 08:12 PM, ID: 25522134Expert Comment
[+][-]10/09/09 06:26 AM, ID: 25534686Author Comment
[+][-]10/09/09 07:29 AM, ID: 25535340Expert Comment
[+][-]10/09/09 07:29 PM, ID: 25540458Expert Comment
[+][-]10/10/09 10:13 PM, ID: 25544947Author Comment
[+][-]10/10/09 10:15 PM, ID: 25544952Author Comment
[+][-]10/12/09 12:11 AM, ID: 25549086Expert Comment
[+][-]10/12/09 01:10 AM, ID: 25549258Author Comment
[+][-]10/12/09 04:24 PM, ID: 25555918Expert Comment
[+][-]10/12/09 11:14 PM, ID: 25557311Author Comment
[+][-]10/12/09 11:16 PM, ID: 25557320Author Comment
[+][-]10/13/09 01:30 AM, ID: 25557929Expert Comment
[+][-]10/13/09 08:14 AM, ID: 25560863Author Comment
[+][-]10/13/09 01:01 PM, ID: 25563853Expert Comment
[+][-]10/28/09 09:29 PM, ID: 25690659Author Comment
[+][-]10/29/09 04:12 AM, ID: 25692343Expert Comment
[+][-]10/30/09 09:43 PM, ID: 25708459Author Comment
