Range Extender for Linksys WRT150 N
Asked by computerlarry in Wireless Networking Range Extenders, Wireless Network Access Points, Networking Hardware for Macintosh
I need to extend the range of a Linksys WRT150, which is a wireless N device.
I want to do this as easily as possible, since I have to work over the phone and remotely with TeamViewer when I do this.
I assume that using a Linksys device will work the best, but Linksys doesn't have a range extender that uses wireless N.  They have a G model, which the Linksys Tech Support site indicates won't work.  (Although some may have lucked into getting it to work)
"My range extender worked with my WRT150N router for about 6 months, and last night it just disassociated itself with my network, and now it won't go back. Some linksys guy told me it wouldn't work, but I know it will because it has for 6 months. Can anyone help me set this up?
The tech is correct that the range extender will not work with N router ..... however if it is working fine for last 6 Months in your case .... you can try reconfiguring the Range Extender ...according to the wireless settings in the router ...."
Here's the link for the above conversation.
http://forums.linksysbycisco.com/linksys/board/message?board.id=Range_Expanders&thread.id=2547
Does anyone know if an Airport Express N will work?
Thanks.
Larry
[+][-]08/04/09 04:54 AM, ID: 25012583Accepted Solution
Zones: Wireless Networking Range Extenders, Wireless Network Access Points, Networking Hardware for Macintosh
Solution Provided By: Darr247
