Time Tested Wireless Ethernet Solutions: 1 - 25 of 80
My system: Win XP SP2  updates current I.E. 6.0.2900 SP2 Program at issue: VZAccess Manager ver 6.7.1_2044c-Novatel (Smith Micro Software) Problem:  After VZAccess Manager is insta...
I have installed windows server 2003 r2 sp2 x64 on DELL latitude d830 laptop. i was unable to install the Intel PRO/WIRLESS wifi drives. i get this message "no wireless network adapter was fou...
Opening an attachment in OUtlook 2003 get a message "The system cannot find the file specified.   If I open Word first and minimise it and try to open the attachment in email works perfectly. ...
Hi, I'm trying to connect to the FTP host on Godaddy but am having problems. Here is the info I'm putting in under the "remote info" tab: Access: FTP FTP Host: ftp://whatyouseeyoucannot...
I'm running BackTrack Linux ( http://remote-exploit.org/backtrack.html ).  I am trying to set up a wireless network connection.  I  have 2 wireless NICs available: an embedded Broadcom NIC (MA...
hi everyone, I have 2 cisco wireless access point which i want to install in my office , but i dont want them to be different SSID as i want both to generate same ssid so if users get disco...
I got a linksys dual band wireless router and tried to hook it up with my verizon DSL Westell 6100 modem. I could not configure it and I think that there is a problem with the modem. How can ...
I just reinstalled windows XP on my IBM T42, went to Lenovo to download drivers, found what seem to be the appropriate one, downloaded it, used the device manager to try to install it, and am ...
I have a Linksys WRT54GS router, with the latest firmware updates from Linksys. I have the router set up for wireless internet access at home, and when people connect to the router, then ca...
Hi, I'm trying to set up a wireless home network. I have a Gateway desktop running Windows Vista. The DSL modem/router is a 2Wire Gateway 2701 HG-B. The laptop I am trying to connect to is a ...
Does anyone know if the D-Link WBR1310 wireless router can be put into bridge mode?
WiFi works fine most of the time, but goes down every few hours or so and cannot be re-established without re-booting computer. The symptoms are:  the ProSET icon in the system tray goes yello...
how can i verify if someone is using my wireless router furtively? i've a dlink but it's a general question. what program can i use?
Hi Everyone;         I am trying to help a friend with a WiFi Network Card issue.  Basically,  I have this laptop at my home which already has a preexisting wireless setup with an 802.11b w...
I have a large home with several stories. One wireless router is not sufficient for access by laptops,  So we need to set up at least 2 wireless access points.  I have two (2) DIR-655 DLINK wi...
Need help to install Intel PRO 2200bg or 2915abg Mini PCI adapter wireless  on ThinkPad T42P for CentOS 5.2 Tried madwifi - no luck.
HI everyone, I am unable to connect wirelessly from my laptop. I have had this problem for as far back as i can remember owning my laptop. Recently i had my laptop setup at my girlfriends a...
Hi Everyone:          I am interested in any direct download link for the latest firmware/driver updates for the following network device:  A Linksys WUSB54G 802.11g Wireless USB Network Ad...
Hello folks, I have been through h*** with Belkin's support and their Wireless N USB device. I have never in my life experienced worse technical support. After enduring two months of absolu...
I am trying to update to the latest version of the driver for the Belkin Wireless USB Adapter model F5D8051 (f5d8051v2_ww_2.01.03_w2). When I try to uninstall the previous driver through eithe...
I have a problem similar to the one referenced in another question: http://www.experts-exchange.com/Operating_Systems/WinXP/Q_21915727.html I'm running Windows Vista Business SP1 on an HP P...
I just replaced the modem card with a wireless card.  The computer does not recognize that the wireless card exists.  What should check before assuming the new card is bad?  The computer is a ...
OK. I have a situation. One of my customers recently upgraded the wireless security from 128 bit WEP to WPA using TKIP and a radius server that authenticates against a domain. I helped them im...
I have a wireless router.   It is New.   I have configured it with WPA, changed SSID, and changed channel to #2. -   I have one wired computer connected.   It works fine. -   I have one la...
My client has a Windows Server 2003 domain network that I set up.  I have three Windows XP workstations, all Dell (one Optiplex 745 and 2 Optiplex 320's), with Linksys USB wireless adapters (W...
