Hello all,
4 APs (Cisco aironet 1130) with overlaping, WPA/TKIP, 802.1x authentication, Protected EAP, MSCHAP v2 without "Automatically use my Windows logon username", hidden SSID, machine ...
My boss has provided me with a Lenovo ThinkPad T61 (Windows Vista Business), with IBM Access Connections software to manage my wireless connections. I've connected through my home WiFi network...
I used above card in Australia with ISP "3G",2 years before.
same card want to use in India with some CDMA operator, not getting drivers for my Dell D620, win xp sp3.i used same old drivers b...
I have a few brand new Cisco 1240AG access points. They work fine if plugged directly into AC power via the adapter but if I use the power injector that goes with this model the radios will n...
My client has a Windows XP computer connected to a Sonicwall TZ150W to allow for remote access to her office. Her daughter just received a Sony Vaio laptop with Vista Home Premium. I have conf...
WinXP SP2 in use, Intel/Pro 2200BG with Driver v9.04.37
Read the boards on others having this problem but back in 2005 and tried some of the fixes but nothing works. The laptop is sitting ne...
I'm using a Linksys Wireless Adapter PCMCIA card with my Dell Inspiron 5100 laptop. The model is Wireless-G Notebook Adapter version 4.0. My router is a Linksys WRT54GS with the latest firmw...
Hi all,
I've got an WLAN Controller 4402 that I need to configure to control some AP 1131. I think I setup the WLAN controller correctly and I added the DNS name to the DNS server.
If I co...
Hi Experts,
I am beginner on this subject though I have configured RADIUS server on Windows Server 2003 Standard Edition.
I have used following articles to setup RADIUS:
http://articles...
I have a Linksys wireless G router and it has given me problems on several occasions. It will work for awhile then it will stop for awhile. I bought it several years ago and I am thinking mayb...
How do I secure wireless access to my D-Link Router home network?
If my neighbors can see it I don't want the accessing it. How do I set the internal? password?
I have a Linksys WRT54GS wireless router at home. One of several XP PCs cannot connect. Other PCs can connect and have Internet access. The problem with this one problem PC started 2 weeks ago...
Hi, I have two PCs on a wireless network, one of which is very troublesome. I regularly get a call saying that they have lost network connectivity. Invariably when I go to the PC it's always t...
I've had Netgear router and had intermittent wireless connection issue. I've replaced that with lastest Wireless-N router (WRT-310N) from Linksys. All devices are connecting via Wireless-G m...
I am doing a wireless N network with a Linksys Router and a Linksys adapter. When I am right next to the router I can start my laptop using Windows XP and connect to the wireless network no pr...
My Dell D600 laptop has Intel Pro/2200BG wireless adapter. It fails to get IP everytime using DHCP with my linksys and netgear Access Points. It gets "connected" after 60 seconds but has priva...
I think the answer is "can't be done" but I'm asking here just in case.
I tried manually putting in this route:
0.0.0.0
0.0.0.0
192.168.2.10
And tried having it drift over by RIP fr...
I was trying to connect to a wireless network where I did not have good reception at all and I get "local only" on my Vista machine. I also have a laptop that has XP and that has no issues whe...
I am trying to get a home wireless network set up between 3 computesr, with others to be added later. I have been doing this using the wireless network wizard that comes with windows XP. So fa...
I am looking for a professional opinion on setting up a Wireless Network for a school. I originally had a company come in, and give us a quote for setting up a RADIUS server, repeat...
I need to share a wireless ISP connection. At this moment one PC with a Wireless NIC connected to outdoor antenna is connected to WISP using PPPoE connection. I would like to share this connec...
I have setup a Linksys WRT54GS router as an Access point and i am attempting to configure WEP with a passphrase for simple security. When i attempt to connect to the router with a lap...
I am going to be doing a wireless install on a older building. I think it's three floors with brick walls so I know wireless is going to be a pain but that's what they would like to have.
M...
http://www.netgear.com/Products/PowerlineNetworking/PowerlineEthernetAdapters/XE102.aspx
I have one internet connection (DSL). I want to provide secure public wireless internet access to the lobby of my building for any building resident to use. I also want a private wireless ne...
