Time Tested KVM Switches Solutions: 1 - 21 of 21
  • 1
Some computers that I connect to my KVM Switch come up with the USB Device Not Recognized error and I can get video still, but have to use a separate Keyboard and mouse instead of the ones con...
Has anyone had any issues with installing a KVM 2160as box.  I purchased this unit new in the box, but can't seem to get it to work.  The unit came with 16 SIP (system interface pod).  I tried...
I foolishly purchased the following KVM switch which as it turns out has the wrong DVI connection for the PCs I want to use it with. https://www.lindy.com.au/online/arrshop.exe?anonymous=true...
I have three PCs connected through a Starview 4 port Micro KVM Switch. I find that sometimes a computer connected will not sense the mouse and keyboard after the switch has been off that co...
I have a PS2 KVM switch. I'm trying to use PS2 to USB adapters to plug up the server with the KVM switch. I get "Unrecognized USB Device" everytime I plug the adapter into the server.  Can som...
I just bought a TrendNet USB KVM TK407K.  I have two Acer desktops with a Dell keyboard and Microsoft Mouse. I use the buttons on the KVM to go between the two computers.  I need to switch be...
We have an associate who uses a seperate PC to run payroll once every other week, and we have been trying to get her setup with a new KVM switch.   For a little better perspective, her main...
Can someone tell me the default user name and password for avocent dsr2035 KVM? Thanks
I'm looking for an IP based KVM that will allow me to console into a cisco router and will also allow me reboot the router in case i want to do so. I know all of this can be accomplished throu...
Does anyone know of a quality KVM switch suitable for a serious gamer who is wedded to his IBM model M PS/2 keyboard and also needs USB for the mouse, sound and DVI video, or at least high qua...
We moved 2 servers to a back office.  They had a generic KVM switch where they are.  We need to run some type of KVM extension so we can extend the keyboard/mouse etc.  We just need the end us...
I 've got four PCs connected to a regular 4-way KVM switch, all connected to one ..... 26" monitor (using vga) + mouse + keyboard + speakers + mic. In addition one of the PCs has a touchscree...
This is my first question and it's mostly academic since it happened a few years ago.  Sorry if the details are fuzzy and I apologize if fuzzy details makes it difficult to answer the question...
Hello, I have read many, many posts here on EE trying to find an answer to my question, but am finding that each situation is so different that none of them match my question. I would like ...
I have a dell e6500 laptop connected to an avocent autoview IP KVM.  When I initially hooked it up, I wasn't able to see the screen  in the kvm session- no signal.  I then set the nvidia displ...
I have a HP Mini 2140 netbook which is fitted with an Intel GMA 950 gaphics adapter.  When I directly connect my 22" monitor it runs normally at a resolution of 1680x1050.  I connected up a Be...
I've been using a Trendnet KVM solution for about two years.  Well, it started acting up and I figured it was on it's way out.  So, in a fit of technology rage, I hastily through it in the tra...
Hi all - I want to be able to share two Cinema displays with two Mac Pros and also have both Mac Pros share a single keyboard and mouse. I have been looking for solution but am getting lost...
I have Transduction TR-570 Rack Mounted Workstations that are connected to a KVM for access from other offices, when the video "goes to sleep" you cannot access it from any other KVM access po...
Hi, I have successully used this ATEN KVM 1734A in the past, however since relocating my server set up to a new office I can't get the KVM to work. The two problems are: a) it wont recognis...
Hello, I have a desktop pc, and another laptop.  I am using my PC's screen, mouse & kb on the laptop nearly everyday.  However, this is being a pain having to plug out the kb, mouse & scree...
  • 1
