I have an Alcatel ADSL modem (SpeedTouch 510) with the software release version (5.4.0.14) need to modify it as a Router. The problem is that I don't know both the administrator username and p...
I fixed the caps and im sorry im running windows xp i am hooked to broadband thru surfboard modem. when I type in 192.168.1.1 to configure the router it tells me the web site is not responding.
I'd like to know the default password for this model.
I tried 1234, admin but all did not work.
I stored my user and password to connect to my ADSL in there so I cannot afford to reset the ...
Hi Experts!
I'm one of those "knows just enough to be dangerous" people when it comes to this networking stuff and thought I'd let somebody that knows what they're doing help instead of muc...
I just got a "new and improved" DSL service from Earthlink and after two hours with the tech guy, they were clueless. One of the worst tech support experiences I've had. I was just about to ...
I am using Windows XP and I am receiving a blinking error message that says Local Area Connection, A Network Cable is Unplugged. I have a cable modem plugged into the ethernet port. The ethe...
I recently got Comcast High speed cable modem at home with 5 static IPs. I would be grateful if some one can recommend a good solution to network 2 servers such that they can be accessed ...
Here is the situation...
I have 2 computers hooked up to a 4 port Linksys router. My computer gets the connection through it, my roommate's does not.
I've searched for solutions on Linksys...
I am monitoring a free wireless network at a apartment complex that has 250+ units (plus nearby individuals that are catching and using the free wifi). I have access to a dashboard ...
I have seen a couple of posts where people claim that they have been able to find the login information for admin account for the SMC8014 Comcast Business IP Gateway. I don't need t...
I have a DSL Verizon Westell 6100 modem/router. I have a Linksys Wireless router behind the Westell 6100.
I have a small network behind the Linksys Wirless router.
I also have the need to ac...
It drives me NUT. I setup several times before without any problem but this one is crazy. My friend had to exchange the third Lynksys wireless router which has 4 ports cable. We follow instruc...
I recently moved and my only broadband solution at the moment is Bellsouth FastAccess DSL (bellsouth.net).
I had been using Comcast cable-modem for several years prior to this with no difficu...
I have a Scientific Atlanta DPC2100 Cable Modem and I would like to know how can I SHARE my connection through the modem? I Have a switch and 3 other W2k Boxes. Today I connect the modem to on...
Hello Folks,
I have a couple of Speedstream 5200's that I need to access the web interface to change the VPI/VCI.
I have followed the reset and web access instructions to no avail.
Her...
I use an AJP laptop that I connect to my broadband internet account via a cable modem. Recently when I connected the laptop the internet connection came up with limited or no connectivity. Whe...
HI
I have broadband internet and I get 2 IP's from my provider. so I've bought a router and connected my old PC to the internet... Both PC's have internet, but the problem is that I can't c...
I recently signed up for Comcast cable internet and digital phone service and the installer came out and hooked up a modem that runs both the internet and phone services. I plugged my compute...
I have recently purchased a Westell A90-36r641 DSL router & cannot get it so connect to my ISP (BTOpenworld). Telnet to 192.168.1.1 is possible but I'm prompted for a U/name and password, whic...
HI
I have a 2611 Cisco Router with a WIC-1ADSL configured and working fine but I want to know the sh commands to check sync speed. WHen I do a 'sh atm pvc' or 'sh atm interface' I can see u...
Does anyone know a way around the blocks that road runner has on using a different SMTP server. I trying to use my company's SMTP to send out mail but roadrunner is blocking me from doing that...
I need to configure my firewall to get access from outside.
1. What port(s) need to be open for Windows XP remote Desktop?
2. What port(s) need to be open for Windows 2000 Terminal service...
I have a dsl connection to internet, needing to change some settings in the modem. the modem is a comtrend ct-5071 I need to know how to access the modem. Password etc. for them
A clients computer is unable to access the internet at all. When I first went and saw them, I found that their modem had a dodgy power button and any slight movement would turn the modem off. ...
I have to expose my ignorance. What is a DSL modem? The term sometimes seems to be used interchangeably for a router. Are they the same?
I have DSL, but I do not have a "DSL Modem"--my t...
