Hello!
I want to open certain ports for tcp and udp traffic in my pc that is part of a wireless network connected to a router. This router is only used to provide network connection, since ...
I'm using an Alcatel Speedtouch USB modem under Windows XP to connect to an ADSL network. Every few minutes, I get a "network cable unplugged" error and I am dropped from the network. The ca...
Ok, so a little background.
I currently subscribe to cable modem service from my cable company at 1mb. I had a Com21 cable modem hooked to a Linksys router that was assigned a static IP. ...
Can someone please educate me on what the settings should be when configuring a wireless router (hardwire to wan/dsl modem) behind a Bellsouth westell 6100 modem? As regards the IP addresses,...
I have a Linksys router which has stored the username and password for my DSL connection. I want get this password for the PPPOE DSL connection from the linksys router, but when I go to the a...
2 people both with ADSL routers. They are on internal LAN PCs with addresses 192.168.1.x issued by their respective routers. There are other PCs on each of their networks.
What IP address s...
Hi All,
I have a Comcast SMC Business cable router. I need to be able to manage this router from the internet. I have a static IP address and I am able to get into the management interface ...
I need help with a SpeedStream 5360 DSL modem. I don't have a manual.
The modem appears to work, synchs with the dsl signal etc. BUT I don't know how to access the modem to configure it. ...
I have a user that is trying to take his laptop to his home and connect to the internet through RoadRunner. They provided him an Arris telephony modem for his data and voice, and he just purc...
I have three question regarding to DSL.
Q1. When the tech comes to my house to install DSL, does he actually run
the twisted pair from the corner to my house, or he uses my existen...
Ok, here is my problem. I play online games alot and here a couple months ago I started to get intermittent lag while playing. While im playing counter-strike, about every 30 seconds to 2 m...
Hi Experts,
Can anyone tell me the default password for a Dynamode DSL Router ? The username is admin, I have tried all the obvious one so far to no avail.
RangerLad
Windows 2000 error when attempting to connect/register with DSL.
Unable to connect Error 769 The specified destination is not reachable
Checked with DSL provider and verified server is UP.
I have DSL, VOIPyourLife service, and a router.
My connections go like this:
DSL phone cord --> Qwest ActionTec M1000 DSL Modem (and apparently, router) - Only 1 Ethernet out
M1000 -...
I'm using Windows XP Professional.
I just bought Linksys Wrt 54g router to use my existing cable internet wirelessly. I went through the step-by-step guide provided with the router in a cd fo...
I have hooked up a Linksys wireless router G to a Verizon DSL connection, the DSL has internet connection and works fine, the problem is when I hook up the wireless router it cannot connect to...
I have Verizon DSL. I have a Westell 327W modem/4-port router with wifi. I have never been able to connect from home to office using Cisco AnyConnect VPN. I can connect from other locations...
hey everyone.i'am new to this dsl.just got dsl through verizon.have westell 2200 modem model #A90-220015-04.says on bottom of modem dsl router.tried to connect useing linksys EZHUB04 hub it co...
I have a DLink DSL-G604T Wireless Modem/Router that i use to connect to the internet at home. I have no problem using the device as long as I set the connection type up as Bridge (dunno why, ...
I brought a batch of SpeedStream 5100 B from CDW, it doesn't look like there's any firmware in it. This is the second batch of SpeedStream that I brought and still the same thing.
Normally ...
Hi guys--
I have had an older Motorola Surfboard SB4200 modem that has worked successfully for 3.5 years on Coxs cable network. In the past three months, it periodically loses connection ...
I have 2 systems networked (1-Win2k, 1-WinXP) using the Linksys phone line connection. The Win2k system has a cable modem plugged into the USB port. I have internet connection sharing turned...
Does anyone know the default password for a westell 6100?
There is a belkin router in place behind this modem and i'am unable to open up ports to my lan
From doing alittle research i've fo...
Dear Experts,
Short version of my problem:
My Qwest/Actiontec DSL modem will assign IP addresses to my wire-connected desktop and my slightly older Dell laptop. My new Dell laptop, howev...
I have Verizon DSL service, with a Westell Modem. I know this modem is a router itself. Also I have a SMC Barricade 4804WBR router, which is connected to Bellsouth Westell Modem.
Actually i ...
