What do you think about Windows 7? Write a review or a how-to about Microsoft's newest product and earn unlimited points!
Time Tested DSL / Cable Solutions: 626 - 650 of 653
I have a DSL connection and only one computer connected.  Can I connect a second computer to the DSL?  Will I loss bandwith?  How do I connect two? Thank You JCT
    Yes, I have recently helped a friend who had 12 Trojan horse viruses on his computer.  Unfortunately, all 12 could be detected, but, not cleaned.  So, we had to delete the corrupted files...
First of all, yes, MSN allows connection sharing but only if you can figure it out and they don't support it. Situation: Server (desktop) runs Win2000 Server.  Has two NICs. Client (lapto...
Hello, I am trying to configure a company's router for their new DSL line with static IP address. I brought the router home and hooked it up to my DSL line and using my dynamic IP address con...
This has been going on for a few weeks now and I'm getting somewhat frustrated. Here's the skinny: SMC Barricade7004WBR was just bought to hook up to the Alcatel SpeedTouch Home which we us...
I was just wondering if there are any advantages of using PPPOE versus Frame Relay or RFC1483 for a business DSL line.  We currently have business DSL lines at our remote locations.  Most of t...
I have DSL from Qwest coming into a cisco 678 modem. The modem is connected to a linksys broadband wireless (g) router (WRT54G). My pc is wired to the router using a NIC and TCP/IP. The pc os ...
I've got my SMC router properly configured and have no trouble sharing my dsl connection with all computers on the network, the only problem I have is that my router seems to disconnect at ran...
I am using a USR broadband router. Port forwarding is possible on this router (it is called virtual server)however the ip address of the pc to which a particular port is forwarded to should be...
how fast should a dsl connection be? My network status says connection is at 100 mbps.  Should I expect more, and how can I see exactly how fast the connection is?
I have a webcam that i know is working connected to my windows XP workstation. this runs to a linksys adsl router. when ever i try to have a web cam session with any of my buddies i get a p...
I'm setting up a small network and I'm having some problems getting the Actiontec wireless GT701-WG modem gateway and Sonicwall TZ 170 to work together. I'm running a windows 2003 server ru...
We just set up a wireless network using a D-Link DI-524 router. I am wondering, is there a way to constantly monitor the clients connecting to the router? I know you can go to the admin webpag...
Hi I need help with the configuration of my home network. Here is how it is Internet ----DSL ActionTech Modem-------Switch ---Winxp                                                        ...
Ok, I'm a programmer so software is more my thing than all this hardware stuff.  Here's my problem.  I recently added an AT&T 6800G Plug&Share Wireless router to my setup.   I have a Motorola ...
I want to use pcanyWhere between 2 distant PCs with DSL and a router. My system is Windows XP SP2, both sides. The support of Symantec is very week ... I know that pcanyWhere uses ports 5631...
How can I setting up my SMC 7401 Router for FTP server or WEB server ? Please help. thanks
I have a Netgear Wireless Router.  The router is directly connected to one desktop PC via a cable.  I have two other pcs that I want to hook up.  I have a wireless card in those computers.  I ...
Hi!  actually, having only one DSL is not enough. Instead of going with a T1, which is like $1k/month and since SDSL is not available where we are located, i would like to get 3-4 DSL connect...
I have Windows XP Pro SP2 on a Sony VAIO notebook, PCG-Z1VA. The Sony laptop includes an Intel/Wireless 2100 3B Mini Adapter with the most recent driver update by Sony, 1.2.1.7. I have an Ethe...
Hi, I am trying to VNC a machine on my small home network using the NAT external IP address My Port Forwarding configuration of my router is as follows; # Private IP Protocol Private ...
Hello, I have Bell South FastAccess DSL ta home and Bell South FastAccess DSL at our business. I have a static IP address at both. Our business runs a web server, vpn server and mail server...
I have a Linksys RV082 router. It cannot connect to the Internet via my DSL provider but works just fine with my Cable Internet provider. More baffling, the DSL works just fine when directly c...
Hello experts, I have just installed a usb adsl cablemodem to get braodband from tiscali. I however need to have wireless so that I can use my laptop anywhere in the house to access the int...
I need to wirelessly bridge two networks using Linksys WRT54G routers securely. Does anyone have detailed steps needed to accomplish this ? One router will be the Internet access gateway and h...
