I have Verizon DSL service, with a Westell Modem. I know this modem is a router itself. Also I have a SMC Barricade 4804WBR router, which is connected to Bellsouth Westell Modem.
Actually i ...
My very well-meaning brother installed some verizon software on a computer hooked to a gt704wg actiontec router. This was a verizon router but is now connected to snet/sbc/yahoo/at+t or whate...
I have a linksys wireless router, I would like to install on my desktop, running win xp. I also have vonage phone service on the same computer, I would like to know how to install the router w...
My network consists of an ADSL modem/router and a Wireless router. The ADSL modem automatically dials the PPPCoE connection and have the option to keep live. If I put the modem in Bridge m...
Anyone have a config for a Cisco 831 need to bridge (Is bridge the right term? When connecting the Motorola/Netopia 3000 modem to the Cisco router?) a Netopia 3000 modem to the Cisco router.
I have a Linksys BEFW11S4 with Firmware Version: 1.52.02
I don't think I can update the firmware anymore.
I have 4 computers hooked up to a Linksys Network Hub NH1005 and then that is conn...
I have several PC's on a small network, all sharing the internet through a router that DOES NOT allow for any kind of MAC address filtering, or anything much else, for that matter (it's a rout...
I check the "Use Windows to configure my wireless network settings".
After I reboot the computer this setting is unchecked again.
System:
IBM T30 Notbook
Intel wireless adapter (integr...
I have been running wireless broadband for the last year through my laptop connecting to a zyxel P334-wt which in turn
connects to a wirless broadband connection (antenna on the roof job to ...
Im trying to configure a LAN with a linksys router behind a westell b90 modem from Bellsouth. I configured the westell for a Bridge ethernet and conection type on demand. Then got in...
Windows ME
Server = Windstream
DSL Modem = Speedstream
Router = Linksys Wireless B
Have Home Network of 3 Computers ( 2 wireless & 1 wired to router)
Has been working fine for 4 years u...
When installing Virgin Media ADSL Broadband (http://allyours.virginmedia.com/html/internet/noncable.html), is it possible to just download and install the modem driver from the address below, ...
We have a small business with a Comcast SMC8014 Router. I would like to be able to vpn into 1 computer from home. It gets confusing when I read the documentation about port forwarding, etc. ...
Hello all,
I am trying to set up a VPN behind an SMC 8013 Cable Modem, and I'm running into IPSec pass-through difficulties that should be alleviated by placing the modem into bridge mode. ...
I am looking for a good ADSL modem that is compatible with my Verizon DSL.
I currently have the small box Westell modem that, in my opinion, is absolute garbage.
I've been looking at the D...
I have a Linksys WCG200 Wireless-G Cable Gateway and everything functions fine. Using the browser interface (192.168.0.1), I tried to change the password, but as soon as I hit "save settings" ...
I am 19000 feet from the DSL telephone company switch and therefore have an attenuation of 63.5. As a result, whereas I could get a speed of 1.5 if I was closer to the switch, the telephone c...
I just switched from a no name DSL company to verizon. They gave me a Westell DSL modem/router. I have 5 computers hooked up through a netgear router. and I am unable to connect any of the com...
Westell 2200 works if I connect direct to my PC but if I connect the netgear wireless router, I can't connect to internet. I don't have the verizon username and pasword.
Is there anyway I w...
Hello, I am trying to setup the home network for my boss. I have a Speedstream 5360 DSL modem that connects to a Linksys Wireless G (WRT54GS v2)4port modem. From the Linksys router there is a ...
The problem:
When setting up an internet connection manually using the Windows XP pro internet connection wizard and trying to connect to the internet through one of my computers I get gra...
I have a Sonicwall TZ 170 running the latest firmware, I just upgraded my line to a 3/768 Buisness DSL package with 5 Static IP addresses. I wanted to ask if it would be possible to use multi...
Hello. I have a concern. First, I am running Windows Vista Ultimate Edition. At times when I am on online, out of the blue on its own or if I manually run Windows Network Diagnostics, I will g...
Hey,
I have DSL at home. I'm having a problem getting the idea through the head of someone that they are not the only person living here, using the DSL connection. Meanwhile this single per...
I have high-speed internet with Comcast - an Arris modem, model TM502G with a single ethernet port. I've hooked it up to two different Cisco switches as well as a LinkSys workgroup switch. I...
