We have a facility roughly 1/4 mile away. We've tried line of sight 802.11b bridges but have continuous problems due to the amount of trees located between locations. Is there a way to use d...
We are running a new Watchguard Firebox X750e (with Fireware 9.0 on static IP Verizon Business DSL via a Westell Versalink modem set to bridge mode) and able to connect/manage remotely with Wa...
Thank You again!
Netopia 3000 DSL modem from Bell South has desktops hard-wired to it, and it has wireless also.
Have several desktops in nearby room that I want to hard-wire to a D-Link...
In response to a question about how best to cable for a dsl modem it was suggested that I find the best MTU setting by testing with ping -f -l 1470 kernal.org and finding out how low the setti...
Comcast has installed a new router along with five static IPs; actually, they call it a "Business IP Gateway", and it's a Netgear model CG814CCRv2. Since I'm getting no help from them, I need...
How can I clone my router MAC address (in order to force an IP change from ISP).
I'm using a Linksys WAG200G (firmware version: Firmware Version: 1.01.04), Ive been checking out all the op...
We have recently deployed a SonicWall TZ190 firewall. The WAN connection is an AT&T DSL connection and they have a Westell model 890-610030-06 DSL modem. The modem is in bridge mode and the S...
I am considering upgrading to 4 Mb to 12 MB, but would like to know what the effect would be, not so much for streaming media and file downloads. But more for
A) Interaction with sites with...
Recently my father-in-law, who lives in Lexington, switched to Insight cable for his internet connectivity. He's been using an old Dell PC, with no problem obtaining an internet connection.
Playing Age of Empires III (with both expansions, war chiefs and asian dynasties) on a LAN. There are four players, three of which can connect one to the other, but I cannot connect to anyone ...
I'm hoping someone will know quickly what I am doing wrong:
I have a internet account through Comcast. Modem is a Motorola
Surfboard modem. Use a gateway laptop. I have good connects hook...
I want to use my Linksys WRT54G v2.2 as my primary router/wireless access point but cannot get it to grab an IP address from my Westell Versalink. I read the question directly relating to bot...
Hi am trying to connect two ADSL Modems (Dynalink RTA230 & RTA770) to the Dual WANs on the RV042. (DSL Manuals: http://www.dynalink.co.nz/Products/Rta020/Usermanual.pdf http://www.dynalink.co....
Greetings all! First of all, here's my equipment/network setup:
ISP--Comcast Workplace Standard, 5 Static IP package
Cable Modem/Router--SMC8013WG-CCR, DHCP is turned off, internal IP 10.1....
Right now I am troubleshooting an ADSL connection for the following configuration:
Zoom X3 ADSL modem <==> SMC router <==> several PCs
In this case my PCs belong to 192.16...
Got a customer that wants to use DSL at two different places to get two offices connected to the internet. Then, they want to be able to use a VPN for one to connect to the other, and then str...
I have a DSL internet connection and caller ID on my phone line. Is ther a software or someway to have the caller ID show on my computer when a call comes in?
thanks all
I have Bellsouth FastAccess DSL with a Westell A90-210030-04 model modem. I have a Static IP address from Bellsouth. I have a Linksys WRT54G router. There is both an IP and a gateway IP add...
Hi all,
We have a laptop running Vista business that is all of a sudden unable to connect to our Citrix \ Windows Terminal Servers using either the Citrix client or RDP. We get the followi...
i have verizon DSL with 5 static ip.
i need to set up email server but don't know how to start.
http://www.petri.co.il/configure_mx_records_for_incoming_smtp_email_traffic.htm
the websi...
I was able to find out the WAN IP address assigned to my cable modem using www.whatismyip.com.
I am able to ping this ip address from my computer (thats connected thru the cable modem), but...
My question is very simple:
How do I change VPI and VCI settings on Alcatel SpeedTouch 330?
thanks!
I've a "Belkin F5D8230-4 Pre-N Router" (100 mbps) with latest firmware and a sony vaio with a 54mbps wireless card. The download rate is very slow. (I receive time outs). The upload ...
Hi
I get the following error(sometimes), ping: transmit failed, error code 1 when trying to connect to an IP address(server).
I have no problems pinging other addresses, just this address,
I am in the process of setting up a small Lan. Basic plan so far: DSL connection will be shared via Linksys WRT54G. One computer (Stand-alone PC running XP Pro) connected via ethernet to the...
