Time for your 3rd Quarter Update! Are you in the running for the 6th Annual Expert Awards? Click the link to find out.
Third Quarter Hot Shots
Time Tested Frame-Relay Solutions: 1 - 25 of 51
dear all, If i want to connect my PC to Router's Ethernet port , what cabling shoud i follow?  Straight or cross cable ?? Plzz urgent
hello expert, I am struggling to understand the concept of subinterface on a router. we recently had a local isp configure our new cisco 1841 router for frame-relay connect to our head o...
Hello expert, I have a new cisco 1841 router. I about to configure same for frame-relay . I was looking at a cbt  cisco learning video and the instructor was saying you need to iss...
Hello I will be building out a new infrastructure as we will be implementing MPLS via AT&T service, with two sites in CA, one in CO.  AT&T will provide Internet connection at one site in CA...
I am configuting a Cisco 1841 router to replace a Cisco 1604.  The 1604 has interfaces called Ser0  and Ser0.1 point-to-point.  The 1841 has an interface Serial 0/0/0 which I can configure, bu...
Have a p2p t with two cisco 1720's terminating.  One side is giving me input and abort errors when I do a show int (attached)  the other side is not showing any errors.   My switch is showi...
Using remote access only (not at the physical location of the router), how can I tell if the Serial port frame relay CSU/DSU device is internal or external?
Situation: MPLS frame line with Sprint using a 1760 4 slot router. Slot 0 and Slot 1 each contain a single port csu/dsu WIC. Slot 3 and 4 remain empty. I have two T1 lines, two ISP provided...
I have installed a ds3 card into my 3845, but cannot get the router to recognize the card. It will not accept the "card type t3 1" command either. I am running IOS version "c3845-spservicesk9-...
ATT installed a box on the outside of our building and I am unsure of how to extend the wiring. The box has the following: CKT1 T1/HDSL      YEL\BLK\RED\GRN DATA/DDS    YEL\BLK\RED\GRN...
I'm having problems configuring up an 1841 with a PIX behind it.  The PIX isn't the issue here, it seems to be the frame relay installation.  I received this information from the ISP in regard...
Hi,  I'm trying to simulate Site A and Site B connected via Point-toPoint T1, Frame Relay, or MPLS.  Anyone have instruction.  Currently I have Route A ethernet 0 ip address 192.168.2.1 255.25...
will cisco 2621 router with ver 12.0 (7) with 32DRam and 8MB flash work with bundel T3 which is multi link frame realy. If not can i upgrade this router ? and can you also provide step by ste...
I have a point to point T1 line from one location to another. They both have a cisco router on each end. I was asked to install a firewall on a dsl connection so they can create a VPN and get ...
Helle experts I have been trying to figure out all the differences between the three 'ways' of building a FR network with Cisco routers. From their documentation (CCNA):   (1)  One subne...
Can anyone please describe what I am looking at in the following config, line by line starting with the interfaces? I am a Cisco newbie. Thanks a million for your help.   aaa authentication...
I have a frame-relay circuit that keeps flapping.  It's a 384k fractional T1 frame-relay, with PVCs built to two other remote locations.  The router at the headquarters was an old Cisco Pro 10...
We have an exisitng Hub/Spoke Frame Relay Netowrk.  We are replacing the hub w/ a DS3 ATM Circuit from Qwest (the existing frame network is w/ Qwest as well).  We are working w/ Qwest but have...
I was wondering if anyone could help me with a cisco config for PTP offices, On the main office side, we are using a 3600 router with branch offices already using PTP T1's We are looking t...
Im looking into reselling ADSL in my neighborhood and was curious if anyone has done the math or knows of a average that a T-1 line can handle? You figure that not all users will be up 24/7 su...
Cisco rookie here.  I had to swap out a failed router and used the existing config from the old router on the new.  I changed the name of the serial interface to reflect the serial name on the...
Hey there, Currently we are upgrading our frame relay network to MPLS and I need some advice or recomendations.  Currently we are using EIGRP between all our sites and would like to continu...
I'm sure this is basic to most of you, but i continually am getting stumped by the following scenario. With our T1 came a Netopia router, and a Sonicwall TZ 170 firewall.  Both were "preconfi...
I have a 256K Port/128K PVC frame relay between Massachusetts and Indiana for a access to IBM app at the HQ from remote office.   Does anyone have experience with alternative connections vi...
Hi, It seems like our company needs to install either a frame relay or an ISDN connection into our colocation so our servers can transmit data to a government website to be compliant with t...
