I'm looking for the Office 2007 (real) (wysiwyg) FCKeditor Skin. I'm using it in a CMS and my client is used to the 2007 interface.
Can someone point me in the right direction please...
I am looking for a Joomla component that will give me the conventional drop down menu system that many sites have these days (like this one www.schoolpro.com.au). I found this component http:...
I know very little about Joomla and I need a easy way to have it show pdf files. I want users to click on my news section, select a story and have the pdf version open automatically. I have i...
I'm trying to access my Joomla directory in my web browser (Safari) via my XAMPP local host: http://localhost/joomla, However I'm getting a 403 (forbidden) error. I have all privleges granted....
Please go to http://67.215.225.108 (it is in Spanish).
Find the Main article and click on the "Leer mas..." Link (same as read more in English) The result is a return to the start page (i...
Hi.
I am new to Joomla. my host is www.siteground.com so I install Joomla 1.5 through Fantastico in cp.
I have just one problem which is when i write Arabic, it seems ok while writing. B...
Hi.
I'm trying to create a new Joomla 1.5 template.
I'd like to override mod_breadcrumbs with my own php files.
I've copied the folder /modules/mod_breadcrumbs
to /templates/myTemplate/...
Im looking for some Free Proxy Software, so i can filter internet activity, and restrict some web pages.
Hey experts,
This is the 1st time I use joomla, and I am trying to know as much as I can about it to do changes on an existing site that uses joomla. I found that the following template i...
I've allotted 500 points for the solution to this problem. This is urgent!!
I'm helping develop a website with Joomla! and I modified it to put a custom logo using the JA-Purity template.
Hi EE -
I have just switched to Joomla 1.5 , for a new customer, and need a kick in the right direction. Previously, if I manually
linked to a joomla page , I would do something like:
ht...
How do I can install ZenPack using WEB UI ? I got this error [
Output:zenpack --install /tmp/tmp6-Bx2E
/bin/sh: zenpack: command not found
Done installing ZenPack. ]
i am also unable to...
I'm having a problem that I have seen many posts but no solutions. I have a site that is 98% complete, so many hours in and yet, the home page doesn't load. I get a 404 - Component not found...
I'm using a free template and the top menu and main menu are some how linked. If I publish an item onto the main menu it shows up in the top menu as well. And I have no control of the top menu...
Hi.
I bought a host from SiteGround.com and installed Joomla 1.5 using Fantastico. But, I got a code page problem and discover that some fields in tables are 'latin1_swedish_ci' and I need ...
This can be a vague question - but I was searching for any event management or planning software for the local intranet.
Something like eventbrite.com or Facebook events - but which...
Very new to Joomla. SIte was developed by another developr and I'm trying to figure out how to make the Meta tags title, description and keywords dynamic, as the contents of the main p...
Hi!
I'm running a Joomla!-based website and looking for a widget to publish RSS information from other sites. Please note that I'm not interested in a typical RSS Client (like FeedReader), bu...
I have a VOIP system for my office. Small office with 10 employees running on a T-1 circuit. I have been having a lot of Chipping on the the phones and have been told that a couple of employ...
I'm looking for a Joomla extension that would serve as a ToDo list. I've checked the joomla forums, but can only find one for the back end. I'm looking for one for the front end.
Hi
I am using Joomla v.1.0.15 with www.joomlart.com template. I want to restrict users from submitting content but I dont want to disable user-registerations. New users can only view site a...
Hi Experts,
Allthough this area is fairly new, I hope someone will be able to help me out on this one.
On our environment we are running a job for updating user details from an external ...
i installed joomla a first time after installing WAMP, and then created a second directory and installed it again. problem is - the second installation overwrites the data in the MySQL databas...
Hi i am trying to use joomlaxplorer as an ftp for joomla, i can FTP fine to my server using flash fxp.
When in joomlaxplorer i click on change to ftp mode, input my details but it says the ...
Hey experts/gxp071,
This is about another issue I need to fix for http://www.youkal.net (check http://www.experts-exchange.com/Software/Server_Software/Content_Management/Q_23123720.html ...
