My brother-in-law picked up a nasty virus on his Toshiba, Satellite A215-S5818 laptop. I have run Adware, Spybot, and several other programs to try and remove the virus but it blocks everythi...
We had a power outage yesterday...and now when we tried to power back on the Dell vostro 200 desktop computer it powers on, then only shows the Dell start scrren and beeps six times...pauses, ...
I have a clients Verbatim 2Gb flash drive with EXTREMELY important data on it.
When inserted into ANY machine, it shows up as "Removable Disk" assigned G:.
In Device properties it appears ...
guys, having a huge problem here
cannot start up windows... a user of mine got the message that said "c:\windows\system32\config\system" is either missing or corrupt, please use windows xp cd...
I've been looking closely at the Netapp 2050 and Equallogic entry level PS series (still unsure which disk shelf). I realize I'm not really comparing apples to apples as one is a SAN and one ...
I am going to replace a hard drive in a Gateway laptop and it has a recovery partition on the hard drive. This computer came with an OS recovery CD but I would like to restore it to new condi...
I have the WD My Book World Edition II (blue ring) NAS, 2 500g hdd included. Yesterday, when I turned it on, it was unable to power up. It is configured as a mirror raid.
I removed b...
I have a file that cannot be deleted or accessed on my C: drive. In trying to boot into safe mode, I am confronted with a dialog box asking for a Rescue and Recovery password. I bought the T...
Iam using Veritas Netbackup and sceduled backups are not happening. I checked the console and in the job details the following error is displayed "waiting resource backup-hcart2. Will r...
I am trying to reinstall my os (Windows XP) onto my laptop -- Gateway moodel m320xl, but I no longer have the start-up/recovery disk that originally came with the system. Is there a way to re...
I've trying out the trial version of BESR 8.55.
I assume the normal method of recovery is to create a recovery disk and boot the system from this and then the sv2i file would point the the ...
I have a 1 TB My Book World Edition, with built in ethernet. The drive quit responding - became inaccessible from the network. I power cycled the drive and it did not power back on. The drive ...
I have an approx. 5 year old hp tc4200 tablet pc (1.8 centrino, 2gb DDR, 250gb HDD) that's running (at least it WAS running) Windows XP Tablet pc edition which is really just the same thing as...
I was multitasking this morning and accidentally deleted the wrong VMWare disk from the VM console. The disk was located on a separate physical disk only used for this virtual machine, so not...
I messed up my 4 drive RAID10 configuration, and now my system won't boot.
I have a Gigabyte EP45-DS3R motherboard with an intel ICH10R SATA RAID chipset.
I have 4 Seagate 500GB drives con...
Hi all
From a previous question i asked i found that backup exec is pretty well the best backup solution,
what i want to know now is does it support disaster recovery. I had a server crash r...
I had a fatal crash of my Vista Business computer. Luckily, everything was backed up recently using Retrospect 7.6. Theoretically!!! I have the backup sets - files with the *.rdb extension....
Backup Exec v12, hot fixes installed,
Win 2003 standard, MS Exchange 2003 SP2.
"Use Backup Exec Granular Recovery Technology(GRT) to emable the restore of individual mailboxes...." checked
We have recently purchased a new backup server with DPM 2007. I have successfully installed the Agent on one of our servers running Server 2003. this server is not the Domain Controller. On...
there was a bad drive on my file server array yesterday
we replaced the hard drives, reactivated the disk, and then repaired the disk
when the repair was complete, we keep getting this messa...
I have a Mac and I need to recover some data from that hard drive but the only other computer I have is a PC. I do have a sata to usb cable to connect the mac drive to my PC. Which sof...
i had encrypted 2 (E and G)drives on my Compaq CQ60 laptop on windows 7 Biuild 7100 using Bitlocker, then after i formated C drive and install windows 7 RTM , E drive appears as free space on ...
I recently just acquired a dell 4300 pc, from a friend of mine whose hard drive wouldn't boot correctly. Here is what I've done so far...Booted computer from Slax cd to see if it will come up...
hi all
i am trying to set up a backup with ARC serve r12.5
and every time i run a backup i receive this error
"E8535 Failed to receive data from the agent"
i can successfully submit a job...
I get the BSOD when attempting to boot after restoring an image of my hard drive from last month. I use Acronis and have never had an issue.
Last line in the BSOD says;
prot_2k.sys - add...
