We have a main site with a flat 192.168.1.X network. All the PC's use a Windows 2003 DHCp server to get thier IP. They all point to our Cisco ASA5510 as the default gateway.
We a...
When i try to view the workgroup computers through the (( My Network Places )) it gives me ERROR messege ... check attacked picture !
How can i view them ??
I am wanting to monitor a VMWare ESX Server via SNMP and need a little assistance with how vmware assigns the ID to vmVMID.
Scenario:
I do a mib walk to my ESX server and it returns VMWare...
after installing SP1 for vista this morning i have found that some 2 of the 3 machines on my network cannot longer login to the domain. all i get is the message:
"The security database on ...
Hello
One a my clients has a four LANS that soon will be connected. He need a profesional utility to view these Lans from the IT office. The main issue the he wants to have detailed reports...
Ok guys there are two servers. Both with windws server 2000.
One of thoser server is Cisco CallManager and the Other server is Cisco Unity.
As you know recently the DST changes needed to...
We recently added an HP Procurve 2650 to one of our sites, here is what is occurring and basic configuration:
1. From the 2650, you can ping 10.221.75.2 (DSL router).
2. From the 2650...
I am looking for a piece of software to deploy for network monitorin at a client's site. Basically they are running out of bandwidth and they want to see what traffic over what protocols are g...
Hi
We are running Active Directory 2003 in a small office network with about 40 Pcs running XP Pro.
Unfortunately all our users are local admins. While this is something we want to chang...
I took home from my office my xw8000 (Windows XP) workstation. It was connected to a network with a windows domain using Small Business Server. I wanted to use it in a work group configurati...
I don't quite understand the following scenerio:
I want to Ping from Server #1 to Server #2 across a point to point T1
Server #1 Router #1 ...
I have a Dell 1320c printer with a USB input and a TRENDnet TPL-101U on a home Powerline network. I connected them together with a USB gender changer. Windows XP is on all computers and all co...
INTRODUCTION
Currently, we have a main office with 4 Dell servers (Windows 2000) and 1 IBM iSeries (ERP System), and a warehouse 30 miles away with 5 users. The two locations are connected t...
We have a large flat network and i want some information about the benifits of breaking it up in to logical chunks. Basicaly we have about 2000+ machines connected to the network..
I've got a WAP that's gone missing on a network I'm not in close geographical proximity to.
Is there a command line utility or software to scan the LAN for MAC addresses without getting i...
I need a software to monitor and consolidate event logs for Microsoft Servers 2003 and also cisco firewalls asa 5500 and 5510. Any recommendations?
thanks
I am trying to calculate how many microseconds to sleep to get to a cetrain kbps on a data connection. I need to be able to use a variable for the packet size, and target kbps, and then it sho...
I have a network with next components: 6 PC's, one ADSL modem/router, 1 switch, 1 router and 2 network printers. this is how it is connected
ADSL modem/router, switch and 4 PC;s are in one ...
can anybody guide me good remote support accessing software.
i used to use team viewer but it's not working properly now.
i want all facilities like team viewer and should be simple and ...
If I am given the private ip of 10.18.x.x for myself to use in a network..
Can I further subnet that subnet into 10.18.21.x, 10.18.22.x ?
And maybe even going into the 4th octed to creat...
thought I knew how to exclude an addres..
but im not familiar with the SDM statements found in the config..
If I wanted to exclude 192.168.22.99..how would i confiugre this?
ip dhcp exc...
I'm having problems with routing through my ASA 5510.
I can ping the gateway and beyond from the ASA - 172.31.50.1 & 172.31.3.252 but I can't ping from the internal network through the dev...
I get the error that is attached in the pdf file while logging into the network from my workstation.
I start from a cold boot and cannot find the drive in use any where. The Graphics file is...
is there a way to lock down users pc when the user is still logged in?thx
What I want to do is edit my current DNS CNAME record (http://test) which currently directs to 192.168.1.10 and make it instead point to a SharePoint page I have (http://server.com/pages/homap...
