Hi Experts,
Is anyone aware of a network opensource monitoring software? Something similar to Orion from Solarwinds.
Any freeware utility will be a lot better to avoid any licensing problem...
A client on a site we recently took over has a Cisco ASA5505 as their gateway device. We have been provided with the login & enable passwords. I have some exposure to Cisco OS, but this...
Can one set the proxy settings in a browser via DHCP.
I am assuming not, but surely people have come across this problem and I wonder if there is a solution.
Our students migrate around ou...
Someone caused a network loop and all workstatons and servers became unuseable at a customer site. There was a message in the system tray of each workstation and server that said duplicate IP ...
I want to capture and keep for reference all netflow data from my routers. Every time I try to find free tools for this they turn out to be brain-dead trial versions. Anyone know a truely fr...
Hi, I am running SBS 2003 with Exchange on an HP Proliant ML310 G3 series server with 3 GIG of RAM. My network consists of 30 PC's. I am using Cisco Catalyst 2950 switches. All of my NIC's...
Hi
We have a Windows 2003 SP2 application server that I'm concerned is dropping packets somewhere between the server NIC and the final destination these packets need to go to (which is a se...
Hi Experts,
we has a network with a lot of cisco-switches. Now we try Whats-Up Gold for Network Monitoring. Can someone give me some tips, which SNMP oid's on the Cisco-Switches (and what v...
Hi
I want to find out my network topology using any particular tool or software. Please advise
Could anyone explain to me or provide some information/links that can provide me with the use of command "Tracert" & "Route print". Please also provide me with the explanations on how ...
I have a Conferencing bridge (Avaya) which takes SIP/VoIP calls from an Internet Telephony Service Provider (ITSP), Voxbone. The quality has been perfect until about 2 weeks ago when...
i have cisco 2960 catalyst switch, and i want to configure on it snmp v3 with read, write to report to management software(cisco works LMS)
so can any one help me.
Thanks in advance
We are looking for a bandwidth analyzer tool to measure the amount of SQL server traffic going in and out of our main server, which is running SBS 2003 SP2. We thought MRTG would give us what...
SQL 2000 server at site 1
Clients at site 2 getting slow responce time to data application on SQL server at site 1
Sites are connected via a 10Mps Fibre line that never sents or receives mor...
Yesterday my office experienced a power outage that lasted roughly 2 hours. Although I was able to gracefully shutdown my servers, most of our network computers are set to reboot upon power f...
I have call established between two voip mgcp phones and want to calculate round trip time delay between RTP Packets.How exactly should I do on wireshark
Hi
i need to configure to configure strm to collect sflow data from cisco core switches i would like to know what steps that i need to do for example the strm has two interface ethernet 0 an...
Wondering what the best server management software out there at the moment is ? I need to monitor the usual HDD capacity , process' , services , etc
can anyone give any recommendat...
Does anybody know of an Internet Monitoring software that can monitor my Internet router (cisco 2600). I currently use PRTG Grapher for bandwidth utilization (which is a really good product f...
I cant use netcat keep getting the following error
Cmd line: nc -l -p 23 -t -e cmd.exe
nc: forward host lookup failed: h_errno 11001: HOST_NOT_FOUND
i try to sniff some multicast pakets i send to to port 10000 udp, i disabled all multicast filters and
igmp filters on HP Procurve 2626, so the switch should flood the pakets out of all...
the DC shows that the DNS and DHCP are giving name and IP address to my local network, all PCs can browse the internet, when trying to ping a "some" PC(s) using IP address from the DC it give...
Hi..
Office 1 SQL 2000 server
Office 2 connects to SQL server via a 10M fibre link
User at Office 2 are getting slow response time from the SQL server
Can I use wireshark to spot th...
Hi everybody,
I have a question about the statistics option in wireshark. After running a capture and selecting the 'Statistics' option for 'End points list' does this give you the average...
I've run into a problem that is driving me crazy and I can't seem to find anyone here that can help either so I'm trying to change directions. I'm looking for suggestions on monitoring s...
