Hi Guys,
I have an issue between a Dell 6224 and a Dell 5424 which are trunked. The switches are connected together via port 1/g1 on the 6224 and port g1 on the 5424.
The configs are liste...
Hi Guys,
I have tried to make the attached diagram as simple as I could. The scenario is:
Till recently we had only one ISP1 giving us intrasite MPLS VPN connectivity. We ran into major ...
Took over a network from another IT company. No notes, no documentations.
They have a SonicWall TZ180.
I can't access it.
The default gateway is 192.168.23.1.
I can't open it in an IE win...
PVLAN Configuration on 2 Switches
I'm trying to configure PVLAN on 2 switches including Virtual Distributed Switch.
My 2 switches are:
A: vDS (PVLAN Supported)
C: CISCO 4506 (PVL...
I have a Checkpoint Firewall and I need to configure OSPF Routing to L3 Cisco Switches in another site which are connected by 2 LES Circuits by 2 differnet provider, the 2nd circuit is resilen...
Hi experts,
I have a cisco 2960 switch with vlans and from here trunk port to a cisco 2800 router.
Even the configuration on the end-hosts are the same in area 1 and area 2, i can only ping...
I am trying to change our network from one gigantic LAN to two different LANs and then also incorporate our WAN with the same switch.
I bought an HP procurve 2910 with the hopes of being ab...
Hello Experts,
I have a Netgear Access Point wireless router which is connected to my broadband directly. I have a desktop computer connected through wire and a wireless laptop connected to...
Small business with 65 network connected devices total
Approx 50 desktops/laptops
4 servers (windows)
10 printers + other devices
DG (and only router) is a Cisco ASA5505-SEC-BUN-K9
Swit...
I am having a challenge that I am not sure the best way to solve:
I am replacing an aging PIX with a new ASA 5510. One thing I want to take advantage of is that the ASA supports virtual in...
I have 3 PCs connected through a wired router. One is running Win XP the others are Win 2K. Each of them has NTFS (unfortunately) and they are networked with a Workgroup. I'd like to be abl...
I am trying to configure a Cisco 1811 router. Please refer to the attached image and configuration file (the problem is in the green part). The router is in a testlab.
The router has 2 WAN...
I have to help design a mpls network.. I am trying to learn as much as possible by reading but really need some interactive input. Here is a history and the equipment i have to wor...
We are planning to change our current topology to use VLAN. The main reason is due to relocation and hence not to restrict groups of users to the same location or floors in the buil...
Hi all,
a basic question but i thought i would ask it before i go ahead and do it!
our current network is currently running across one floor (the top floor), we have one server and 10 pc...
Hello Experts,
I'm involved in a project where an enterprise is moving to a new location and due to this fact it will transfer and upgrade its existing infrastructure (Cisco LAN switches, P...
Hello Experts,
I hope someone can help me with giving some input about configuration and possible design flaws which cause our proposed new office network to lose connectivity for a few sec...
So, here's the deal:
We have two office on separate subnets connected through an MPLS. We want to set up a secondary connection through another ISP with a VPN connection between offices and...
I need to prevent my desk top users from shutting down their computers via the shutdown option from the start menu.
I've separated my workstations from my laptops in separate OUs so that ...
Hello All,
Thanks in advance for your input. I recently ordered a business class network for my home - Optimum Online. I was issued 5 static IP's and connect through a modem. Inside the m...
I have two Aironet 1300 bridges that will be connecting from one side of the street to our new location on the other side of the street. Currently our company has 3 vlans running, 1, 22, and 2...
I have network of 4 servers and 4 staff computers. I currently host Exchange SharePoint and I have Domain controller which replicates to different company sites. We are basically the co...
We are geeting one Equallogic PS4000 iSCSI SAN (dual controller) with Dell PowerConnect 5424 Gigabit switches supporting jumbo frames.
There will be be 2 Ethernet Gigabit ports (w/ TOE) on...
I'm searching for a solution that is similar to Private VLAN. I have machines that are in the same subnet but I don't like that they communicate with each others.
My switch doesn't su...
Hello fellow expert-exchangers! Ive been tasked with following request by my manager and searching for best path to completion. He was jotting down some thoughts on flight back from conferenc...
