Top Network Design & Methodology Solutions: 26 - 50 of 78
We have a media server (running xp pro) on 2.0.0.6 controlling a host of projectors and lighting on this network. Subnet is 255.255.255.0 We also have a regular network on 192.168.100.x, su...
Hi I want to configure my EX2007 server to send emails through smart host and not directly through my MX I have a 2008 server DC with EX 2007 When I've installed it for the first time, I ...
How would I setup DHCP on a network with 192.168.1.*/24; 192.168.2.*/24 and 192.168.3.*/24
Hi there, I have a question regarding out network infrastructure that is not really well built, I think. First let me give you a list of our components: * SDSL Connection with Static ...
Hi, We have an AS/400 Device connected on a Token Ring with SNA Protocol and RJE. Need to get rid of TokenRIng and put that device on Ethernet. Even on Ethernet, the user wants SNA protocol. ...
Cisco Catalyst 3500 switches: I created a new vlan and did a "no shut" but its still showing shutdown.   Will it be "shutdown" until it recognizes an IP in that vlan?  I have not yet assig...
Hi,, i am little bit confused about using ip range.  for example i have 3 sites with 200 nodes on each site. so i need three networks connected with router can i use 192.168.10.0/24   19...
I want to know the best practices for setting up an FTP server in a DMZ.  I know not to include the FTP into my LAN Active Directory.  I have heard of people setting up one way trusts from LAN...
Background Info.: I'm looking into upgrading my network.  Dropping Rogers, going to Tecksavvy, getting two static IP addresses.  Ditching my NetGear Router buying a Cisco 851 router.  The DS...
Hi there, since my migration is not success yet., i need the experts to help me to do the migration. here are the situation: i have 2 data centre which one is the latest data centre and ...
I'm going to stage Multiple questions to break this up. I'm a novice when it comes to routing and encountering a few problems properly configuring my ASA to relay TFTP,SCCP and RTP traffic ...
I am helping a fellow physician friend of mine. He is running a domain on Windows 2003 Server with 10 XP Pro machines. Works fine. The problem is he is the only one who can run the domain, e.g...
Can anyone tell me a software package that can be used to map current directory structure and print out a presentable tree stucture diagram?
Hi, We have exchange server 2007 named exchange.smile.local(192.168.1.5) in our local office. it receive the external from 3rd party software, we have implement the UCC certificate(mobile.t...
Current network architecture: First .jpg below depicts current network. All static. Default route on 6506 points to Juniper. All traffic internal and external funnels in/out the 4.5meg se...
Hello,  I just inherited a network and am trying to familiarize myself with it. The WAN network is: 2 Internet routers running HSRP and BGP. 2 ASA Firewalls (active/standby) I have...
I am trying to setup a small business network. This is what I have been given to work with: ISP: Optus Naked ADSL - Siemiens SpeedSteam 4200 Modem IP Address for Modem / ISP Settings Ro...
Hi all, I have the need to create a fully meshed IPSEC VPN topology with an initial 15 sites using ASA 5510's as the VPN terminators.   Currently this will involve 15(15-1)/2 = 105 tunnels ...
Hello everyone, I'm currently trying to figure out how to set up VPN login to an ASA using Windows Domain creditentials.. I wasn't sure what to use, I've seen one article saying NTLMv1 and oth...
I have taken over a network that is really sloppy.  I have been putting off changing the network but it really needs to be done.  Here is my current setup. I have 3 networks that all tie to...
Hi, I want to verify whether or not our network devices are capable of implementing QoS (mainly for future VoIP traffic). We have two Netgear FSM750s managed switches, a couple of Netgear G...
Hi. I should have asked this in my original question, but this is related. If I have multiple switches connected along the way over a 50 mile span, the trunk ports on either side of the swi...
I have this very pesky problem. I have a BR1310G-A-K9 in one building, acting as the Root,with ethernet connection into my network.This device is mounted in the window of an office on the seco...
Hello Team I about to embark on Migrating our current IP Scheme (Public ) to a Private Network. This is going to take some planning and i am looking for some pointers from you on what i n...
I'm seriously considering changing my corporate network from Class C (192.168.1) to Class B (172.16-31). I have computers with ODBC adapters with identical names but two very different configu...
