Congratulations to DanRollins, the first member to earn 50,000 Article points! With 56 articles written, including two Editor's Choice and ten EE Approved, DanRollins is more than worthy of this honor. Keep on rollin', Dan!
Time Tested Network Design & Methodology Solutions: 1 - 25 of 255
Cisco 3560 and Vlans (500 points up for grabs here) we have 2 cisco 3560 switches connected together via fibre using a sfp module runnung as a 802.1q trunk. I have set up 3 vlans on both swit...
I have these 3 switches.  I use a class C 192.168.10.0 subnet. I ran out of available hosts (almost)  I have two options. supernet my existing subnet or route two subnets. Im told routing...
Hello, I working in an environment that has its own seperate network. The network consists of several Cisco 3750 switches. The network also has some devices on it that send out Multicast traff...
Can some one help me to create this in Packet Tracer Ver. 4.11 files and document? 1) Containing basic network (without ACLs) files. 2) Containing the network with ACLs applied files. 3)...
Hello EE, Many of you have been following my posts pertaining to a major upgrade to Metro Ethernet.  Last Thursday evening, we moved forward with 4 of our sites.  Everything went very smoot...
Hi Guys, I have an issue between a Dell 6224 and a Dell 5424 which are trunked. The switches are connected together via port 1/g1 on the 6224 and port g1 on the 5424. The configs are liste...
Hi We two core switches when i try to create new Vlan 1172 in core 2 i am getting "% Failed to create VLANs 1172 Spanning-tree extend system-id need to be enabled." when i checked ...
Hi Experts My network skills are fairly basic and have a problem trying to set up vlans on a layer3 swtich that will: talk to the broadband router to go out to the internet get its DHCP ...
Where can I find a stencil set (.vss file) for Visio 2007 containing all the basic non-model-specific Cisco symbols?
My network is represented in the attached diagram.  The left side is how the network currently looks.  The right side is the equipment I am going to add to make this network more redundant inc...
We are working on setting up a Voip phone system and I am looking at setting up VLAN's on our switches to allow for a tagged vlan for our voice network. Here is what we have: Core switch HP...
I'll try to explain the diagram (attached below) and then relate my question . The question appears a bit long because I tried to simplify it as much as possible for you guys to understand so ...
What is the difference in using straight through cable and crossover cable in connecting a switch? I have read some books that to connect a two switch together you have to use crossover cab...
Hello All, I have a cisco 2950 series catalyst switch.  I setup port fa0/23 - 24 to be an ether-channel and a trunk, with the ether-channel being named Port-channel1. I want to configure...
Hi Experts, I'm setting up a new branch office very similar to the one shown in the attached diagram, and wanted to run it by you guys before buying any equipment. My two questions are:...
Hi Experts, I got a Cisco ASA 5510 with AIP SSM 10. I'm new to this device and wanted to deploy it as shown in the diagram. I have two Internet DSL lines (dynamic IP) and those connection a...
Hello, I'm new to the whole MPLS Setup. I'm trying to connect remote sides using BGP on the providers side and EIGRP on our side. I'm able to ping router from router on each side trough MPLS ...
is it possible to do port teaming on cisco switches. The idea is to use two ports of a 10/100 cisco switch to link a 1000Mbps cisco switch by using port teaming. This because the 10/100 switch...
Can somebody please help me with this question? I'm not sure I understand the 10.10 private IP addressing scheme. All four of these hosts are connected to a switch. My instructor says that com...
Hi Guys, I have tried to make the attached diagram as simple as I could. The scenario is: Till recently we had only one ISP1 giving us intrasite MPLS VPN connectivity. We ran into major ...
There exist several WAN acceleration devices, like Riverbed Steelhead appliances, that reduce WAN traffic through various compression and data reduction techniques. These devices all have in...
I have a big LAN of almost 500 users, in a building of 3 levels, and I have 15 servers (MS-AD, DNS, applications ,etc) every network device  is  in the same  VLAN (1) the default. I have  cisc...
hi, i'm trying to track down a networking expert who is familiar with cisco packet tracer. i have set up a network with various subnets and routers and i am having trouble getting 2 rout...
Dear All , I had a network managed by DC , & ISA Server , Recentrly i got a new internet connection for Doc. Controllers , I need to configure them to work on ISA server using the new inte...
We have a schoolwide network with over 700 computers in multiple buildings.  We have a gigabit fiber backbone and appromiately 60 Cisco 3500XL switches and a 6500 series core switch tying it t...
