We backup our production servers from the home office (10.100.10.x/24) on VM-ware and copy them to our DR site (10.130.10.x)/24. The 2 sites are connected by MPLS links and we are running EIGR...
hi all,
we currently have a 255.255.255.0 network (192.168.0.0) meaning - up to 254 ip addersses.
we also have an "atelis" ip telephony system , meaning that our phone lines also take ip a...
Hi
I have recently acquired a new network, that is located at a single site, accross 2 floors (upstairs and down). This network is running so far on 2x 24 port Netgear 10/100 switches, an...
Hi Experts,
Here is my scenario. In order to supply all LAN computer with a default gateway (X.X.X.X) to route all internet traffic through automatically I have set on the DHCP server a Rou...
I do not think OSPF is properly set up on my network I have the following layer 3 links
4507 Switch GB5/5 Internet Address 10.10.10.2/24, Area 0 (Building A)
Neighbor ID Pri Sta...
Below you will find the situation. Im looking for feedback and recommendations for this. The users are not advance users of technology. Simplicity is important. Up to ten workstations in the ...
I would like to know how to add a static pointer from a computer that has an IP address of 172.16.1.3 to a computer that has 192.168.1.7. The two computers are on a switched network. Any help ...
Using the topology in the file attached to this post, what set up would be needed for workstation A (which already accesses the internet through Server A for logging/permission purposes) to al...
i have more than 300 user in my company and i want to apply the DHCP service in the organisation.
For 250 user i can make one scop for more than that how i will do it........
please send...
At our Admin Office: I currently have three servers in my domain, one is my Domain Controller (Win Server 2000 - origianl server), one is my backup domain controller (Win Server 2000) and one ...
I am looking for a quick answer, hence the points. I am new to networking and could really use some expert advice. I have a router with an IP address of 192.168.1.100 (for example). I have a s...
hi,
I am trying to emulate a WAN to test routing protocols. i am using 2 physical PC's and running virtual machines on them. the networking is using a Cisco router emulator (Dynagen)
how...
Hello Experts,
I would like to troubleshoot the connectivity issues I have been having with my Telco Provider..I have a 1841 Cisco router in both facilities and cisco 2950's on each end as ...
Can someone explain the advantages/disadvantages to receiving the full routing table vs just the directly connected routes?
The setup this pertains to has a few bonded T1's as the primary l...
Background:
I have two office locations, each with a Cisco 3560G switch. It is desireable to have both sites within the same LAN segment (well technically there are a few VLANs, but that i...
I have a very small Architectural Rendering (Visualization) company (with animations coming soon), and we are only two people on the office (the other one is my brother), But we are planning o...
Normally a conventional home network is setup by purchasing a "router" by linksys or d-link or somebody, and it is the dhcp server, hands out IP addresses, shares the internet, etc.. All in on...
Okay so we're looking at possibly making our network uber-redundant. I've been asked to piece together possibilities/costs associated with having dual routers, dual firewalls, switches, etc, ...
choosing a private ip addressing scheme for our Vlan's/departments.
because its private i dont really need to be conservative and use VLSM...
Should i use something logical? or can i use s...
I have a requirement to limit the amount of bandwidth used by certain hosts to communicate to the Internet (but not internally from one host to another within the switches). My netw...
We are looking to switch our network configurations from a point to point to an mpls solution. The impetus behind this is that the reliability of multiple providers for each of the P2P T1's h...
The valid network numbers for class A is 1.0.0.0 to 126.0.0.0
The number of networks in this class is 2^7 - 2
The number of hosts per network in this class is 2^24 - 2
I understand the nu...
We have a single site with multiple servers and about 25 users. We host our own website/client portal, MS Exchange, Terminal server and VPN for remote workers. My goal is to segregate internet...
In an effort to reduce the amount of broadcast on our network I changed the subnet mask to class C
I have an XP professional computer with the following setup
ip 10.21.4.12
mask 255.255.255...
Can somebody please help me with this question? I'm not sure I understand the 10.10 private IP addressing scheme. All four of these hosts are connected to a switch. My instructor says that com...
