Hi all,
I'm looking for some advice on both the design and the particular equipment that would be appropriate for offering some failover capabilities for a small business client.
I have ...
choosing a private ip addressing scheme for our Vlan's/departments.
because its private i dont really need to be conservative and use VLSM...
Should i use something logical? or can i use s...
I'm told there is a D-Link router that supports IP address-based QOS.
I need to configure a QOS policy for our VOIP provider's (vocalocity) server.
I know the best way to set up VOIP is wit...
http://www.alliedtelesyneurope.com/site/files/supportdocs/at1086 This is the link to the install guide for a Centrecom FS708. My en1 connects to a gigabit auto md1-mdi-x 8 port switch with ...
I am trying to use Cisco Netowork Assistant to view my Cisco Switches. When I put in any of the ip addresses for each switch, I get an error message that I am unable to connect. I can however ...
I have 3 PCs connected through a wired router. One is running Win XP the others are Win 2K. Each of them has NTFS (unfortunately) and they are networked with a Workgroup. I'd like to be abl...
I need to figure out how to design and number a mixed 100/1000 MB client environment.
The mix:
" 28 G3 PPC clients only have 100 MB capable nics.
" 15 G4 PPC clients or so have 1000m...
EE
I would like your opinion on the modern state of business class cable/dsl vs. T1 service. The older, conventional wisdom, as I understand it, has always been that T1 is more reliable. ...
I am trying to configure a Cisco 1811 router. Please refer to the attached image and configuration file (the problem is in the green part). The router is in a testlab.
The router has 2 WAN...
Hi
I am configuring a little group of stations 4 in all. I am siting behind a router 10.14.1.0 with a subnet mask of 255.255.0.0 The router will flip me addresses like 10.14.100.14. T he rout...
Hi, i need to create a stack composed by 5 WS-C2960G-48TC-L V03 using their GE SFP, LC connector SX transceiver. I have already connected the fibers (i'm attacching the connection schema), we ...
Experts,
This is a two part question regardling VLANs on my network. The first part asks for your comments on my network design while the second refers to questions regarding DHCP addressin...
I have to help design a mpls network.. I am trying to learn as much as possible by reading but really need some interactive input. Here is a history and the equipment i have to wor...
Hi All,
I have an enquiry for anyone who is willing to help me with a site that im upgrading?
I plan on installing x2 cisco 3750-E switches (which will be stacked) and x3 Cisco 3560-E swit...
I have a windows vista home laptop hooked to my corporate net.
I want to poision internet access so that with the exception of a couple of web sites, Everything and ANYTHING else is blocked...
We are looking to switch our network configurations from a point to point to an mpls solution. The impetus behind this is that the reliability of multiple providers for each of the P2P T1's h...
Hi Guys,
I have a block of /25 ip addresses, and I have a dhcp configure on the router, now am receiving messages that says
Free addresses 0
Address in use : 109
Percentage addresses ...
I've been asked to wireless a small convention center. This wireless on this scale is a little over my head, so I'll be outsourcing the project, BUT I'm very interested in how this would be se...
Similar to this question
http://www.experts-exchange.com/Networking/Network_Management/Network_Design_and_Methodology/Q_24015540.html#a23263005
With a couple of changes.
We have Two C...
We are planning to change our current topology to use VLAN. The main reason is due to relocation and hence not to restrict groups of users to the same location or floors in the buil...
Hi All Experts,
Hope this queston is in the correct area....
My company is opening a small branch office about 30 miles from out main location. We have two servers running Win Server 20...
I am a complete newb when it comes to VLANs, unfortunately the documentation that came with the Dell switches I have hasn't really helped my learning curve. I have six Dell PowerConnect 2716's...
Here is command for policy-map which i can apply on router:
class-map match-all ENHANCED
match access-group 111
policy-map ENHANCED-OUT
class ENHANCED
set dscp af21
priorit...
Does anyone know of a good cisco emulator (preferably free) that I could use? I would like to setup a test environment which is a mirror of our live environent and then upload our cu...
The scenario is like this. Two locations in same AS#100. We will connect with AS#300 through MPLS backbone using BGP with CE routers. So our two sites A and B will run iBGP between them and eB...
