Visit Experts Exchange from your mobile device to search, ask, and monitor your questions. Never lose touch again.
Preview From Your Desktop
Time Tested Network Design & Methodology Solutions: 101 - 125 of 265
I am a complete newb when it comes to VLANs, unfortunately the documentation that came with the Dell switches I have hasn't really helped my learning curve. I have six Dell PowerConnect 2716's...
Hi Experts, I would like to know what's the difference between ISA and Untangle? Can they be installed together on a 2 NIC Windows 2003 Server? If to use one which do you recommend? Thank you.
I need to create a route across the LAN between two Linksys Routers.  An RV016 (LAN1) and an RV082 (LAN2).   The LAN Segments are: 1. 192.168.81.0/255.255.255.0 and; 2. 126.169.71.0/255.255...
Hello Experts, I'm involved in a project where an enterprise is moving to a new location and due to this fact it will transfer and upgrade its existing infrastructure (Cisco LAN switches, P...
Hi I have recently acquired a new network, that is located at a single site, accross 2 floors (upstairs and down).  This network is  running so far on 2x 24 port Netgear 10/100 switches, an...
Hi, We have a Cox Business account and was given a CIDR Block of 13 usable IPs: We were given the following info: WAN IP Gateway IP NetMask Primary DNS Secondary DNS Subnet NetMask...
Hello Experts, I would like to troubleshoot the connectivity issues I have been having with my Telco Provider..I have a 1841 Cisco router in both facilities and cisco 2950's on each end as ...
We are trying to get PCI Certified and we're running into a problem with the PIX 501s we still have deployed as VPN endpoints at remote offices.  One requirement of the PCIDSS is that IKE Aggr...
Hi Guys, I have a block of /25 ip addresses, and I have a dhcp configure on the router, now am receiving messages that says Free addresses 0 Address in use : 109 Percentage addresses ...
In the attached diagram I have tried to make our apathy simple. I'll try to explain the diagram here and then relate my question in hope that malady becomes clearer :) Consider this, we had...
I have two Cisco ASA 5510 firewalls and they both have identical links to my LAN and  WAN. I have two LAN switches and each server has two links one connected to each LAN switch. My questions ...
We have two offices that need to communicate in real time across our WAN (created from an encrypted VPN between the two office firewalls).  As you know, sharing files across the WAN doesn't wo...
So, here's the deal: We have two office on separate subnets connected through an MPLS. We want to set up a secondary connection through another ISP with a VPN connection between offices and...
Hello experts, Sonicwall tz190 does not support vlan trunk, so i connected two wires to 2960. One is going to port 23 of 2960, data vlan, and the other is going to port 24 of 2960,voice vla...
Hello All,  Thanks in advance for your input. I recently ordered a business class network for my home - Optimum Online. I was issued 5 static IP's and connect through a modem. Inside the m...
Due to growing needs, I need to RE-IP my network very soon.  Right now we are on the 192.168.0.x/255.255.255.0 scheme, and have very few addresses left.  So I was thinking of going to this: ...
Why does netdiag throw this warning message - [WARNING] Your default gateway is not on the same subnet as your IP address. Obviously I know why, so I guess the question is why does it matte...
I have one inside server: 210.49.97.208 I have two outside addresses: 10.204.40.8 and 216.98.236.97 At the moment I have the following: ip nat inside source static 210.49.97.208...
Hardware: I have two different WIRELESS routers. 1) Netgear WNR3500 2) DLink WBR 2310 Problem: I want to connect the DLink to the Netgear WIRELESS so that I can extend the signal ...
I have two Aironet 1300 bridges that will be connecting from one side of the street to our new location on the other side of the street. Currently our company has 3 vlans running, 1, 22, and 2...
I currently support two networks in the same building, sharing one internet connection. I seperate the networks using the VLAN feature of our Draytek router and this works perfectly. Unfortuna...
Please see below for a sample of my bandwidth reservations for my classes. I know that by default Cisco IOS reserves 25% for default class and QoS will kick in only when a congestion occur...
Hello EE, We are back again with another question regarding the grand fiber conversion.  Here is the situation. 2 of our sites that are to be moved onto the fiber network require uninter...
I am setting up a satellite office for 2 users, they will come back to the corporate office for all of their files and Exchange. We have a WatchGuard firewall at Corporate that offers clientle...
Hello Experts, I hope someone can help me with giving some input about configuration and possible design flaws which cause our proposed new office network to lose connectivity for a few sec...
