Please see below for a sample of my bandwidth reservations for my classes.
I know that by default Cisco IOS reserves 25% for default class and QoS will kick in only when a congestion occur...
I have a Cisco 1720 router. It has a 10/100 nic. On the other end is a Procurve 2810 switch. It has a 10/100/1000 port. I am trying to figure out why the switch is showing RX Drops. No just a ...
Hello EE,
We are back again with another question regarding the grand fiber conversion. Here is the situation.
2 of our sites that are to be moved onto the fiber network require uninter...
I am setting up a satellite office for 2 users, they will come back to the corporate office for all of their files and Exchange. We have a WatchGuard firewall at Corporate that offers clientle...
Hello Experts,
I hope someone can help me with giving some input about configuration and possible design flaws which cause our proposed new office network to lose connectivity for a few sec...
I'm searching for a solution that is similar to Private VLAN. I have machines that are in the same subnet but I don't like that they communicate with each others.
My switch doesn't su...
We are geeting one Equallogic PS4000 iSCSI SAN (dual controller) with Dell PowerConnect 5424 Gigabit switches supporting jumbo frames.
There will be be 2 Ethernet Gigabit ports (w/ TOE) on...
Hi all. My business has two buildings that are routed together on a private network.
They each have a broadband internet connection which work beautifully but as I have built up a dependancy...
Always ask people smarter than you.
Here's what I have, and what I want to do - for future reference, I'll capitalize the names of the machines so everything makes SOME sort of sense.
LA...
I am looking at the feasibility of a large Rapid Spanning Tree Implementation, does anyone have experience in this area? I would like to answer the following:
What is the maximum number of n...
WHAT IS THE difference between IPVPN AND MPLS
Hello all,
I have a rather complicated issue regarding implementation/configuration of an ASA and the knock on effect that this has had on one of our web servers. I have attached the relevant...
We have a media server (running xp pro) on 2.0.0.6 controlling a host of projectors and lighting on this network. Subnet is 255.255.255.0
We also have a regular network on 192.168.100.x, su...
jac1991:Hello,
Out Network Admin recently quit, so I am trynig to do his job and mine.
I am trying to route all traffic in our Core Router, a Cisco 6513, to an Exinda 6800 wan accelerato...
I am being asked to setup 2 cisco 2811 routers to create a redundent connection to the internet and from the internet to hosted servers inside the dmz. I have the outboud traffic handled with...
Hi
I want to configure my EX2007 server to send emails through smart host and not directly through my MX
I have a 2008 server DC with EX 2007
When I've installed it for the first time, I ...
I am looking for a perimeter load balancer that is scalable and reliable
I am doing a job in a 40 story building where each floor will have an IDF with a Linksys SRW224P or other LInksys Managed Switch with Mini-GBIC ports.
I want to uplink each switch using mul...
I have a W2K3 ENT 64-bit Cluster for SQL 2K5. I added two new nodes to the cluster and removed the older nodes from the SQL cluster. They are however still nodes in the MS Cluster. When I atte...
I am reading a document from Cisco, Enterprise QoS Solution, and I have a question concerning jitter measurement. From the QoS requirement for VoIP, it said that the average 1-way jitter shoud...
We have an AS/400 Device connected on a Token Ring with SNA Protocol and RJE. Need to get rid of TokenRIng and put that device on Ethernet. Even on Ethernet, the user wants SNA protocol. ...
Hi there,
I have a question regarding out network infrastructure that is not really well built, I think.
First let me give you a list of our components:
* SDSL Connection with Static ...
How would I setup DHCP on a network with 192.168.1.*/24; 192.168.2.*/24 and 192.168.3.*/24
At our Admin Office: I currently have three servers in my domain, one is my Domain Controller (Win Server 2000 - origianl server), one is my backup domain controller (Win Server 2000) and one ...
I recently got a cisco 871w router. What I want to do is have my DSL box (2wire Homeportal 1000 HW)run into the routher and then from the router goto a switch where all my other network devic...
