What do you think about Windows 7? Write a review or a how-to about Microsoft's newest product and earn unlimited points!
Time Tested Network Design & Methodology Solutions: 151 - 175 of 266
We have a Cisco CSS - Content Services Switch. We use it for round robbin load balancing. It takes a single URL and passes traffic to 24 web servers. The question is this: Does the CSS take...
Hi Experts, I have following devices and software with me, 1. Cisco 5510 2. HP proCurve 2900 24G ports 3. HP proCurve 2610 48 100/100mbps ports 4. Microsoft SBS 2008 beta This wil...
Hi I am slightly out of my normal area of working, so need some advice from those in the know... Currently, I have 4 Linksys SRW2048 Managed Gigabit Switches in my Network, And have just...
I have 3 windows 2003 standard servers, each with dual gigabit nics.  Server1 hosts our point of sale system and servers 2 and 3 are Terminal Servers.  All three servers and their respective n...
I am setting up a network that will have multiple companies with their own servers and PC's that are going to share the same internet.  I have 2 different ISP's coming in for redundancy and am...
Hi, I have a customer with one old server, which is running as the (WIn2003) DC/File/Print, and also a Terminal Server for 15-20 remote clients. I need to quote them a replacement, but was w...
We have a customer site that uses a WAN-LAN DSL connection (AT&T's Terminology for a very old connection). The WAN IP is completely separate from the usable LAN IPs. The WAN IP is 63.200.114....
I have two ISP links terminated on my ASA, currently sending traffic on both the links, would like have redundancy as well for the same setup. below is the code for the same.
I have a large /20 network that is mainly made up of windows workstations and servers but there is not a large amount of network usage, ie, no large file transfers, etc. There are also a numbe...
Hi, I want to learn the pros and cons of using VPN, MPLS and VSAT technologies. We are planning to connect offices across international locations and want to do a cost benefit analysis cons...
Background Info.: I'm looking into upgrading my network.  Dropping Rogers, going to Tecksavvy, getting two static IP addresses.  Ditching my NetGear Router buying a Cisco 851 router.  The DS...
I want to know the best practices for setting up an FTP server in a DMZ.  I know not to include the FTP into my LAN Active Directory.  I have heard of people setting up one way trusts from LAN...
Hi,, i am little bit confused about using ip range.  for example i have 3 sites with 200 nodes on each site. so i need three networks connected with router can i use 192.168.10.0/24   19...
Hello, Can a new Cisco 3560 layer 3 switch co-exist in a LAN with two layer 2 switches?  I have to buy another switch to increase ports.  I want the layer 3 switch functionality for future ...
Hi Guys, I am going to be setting up Vlans on one of the networks (5 wireless internet towers) and ran into a little problem with the ip addresses. I have the vlans as follows: vlan2: ...
We have two Catalyst 3560 switches with multiple vlans all with assigned IP addresses and InterVLAN routing established.  The two switches are trunked.  The IP address of each vlan is the defa...
Hi, Servers in Vlan 1 servers and VMware nodes are  disconnecting frequently on one specific switch (4510R -E SupV 10GE) only. When we ping problematic server from other servers which i...
I'm looking for reference material (web/text) to help with my networking course. The perfect reference walks through a typical commercial (>100 users, multiple wiring closets and geographi...
Setup: VLAN1: 192.168.8.0 255.255.252.0 VLAN2: 192.168.100.0 255.255.252.0 On VLAN 1:   Default Gateway is 192.168.10.2 (Cisco ASA 5510)     or 192.168.10.1 (Cisco 2611) On VLAN 2:...
I have a good understanding of networking but I'm not really able to answer this question. A current client is running out IP addresses in a /24 network. They will soon be implementing a VOIP ...
What I am trying to achieve is bring Metro Ethernet with VLANs into an existing setup that has no VLANs. I will be deploying some number of Cisco 3550-12Ts to accomplish this (open to other su...
Hi Guys, I just joined a company two weeks ago as a network engineer, and my role is to support my Team lead (We are team of  4, Manager, Team lead, myself and a technician) with some other ...
Here is what we would like to accomplish. We are running out of addresses in a our current Class C - subnet network. We have L3 devices all over the buildings and would like to add VLANs and a...
I have 4 networks that are connected with site to site vpns's. What I would like is the best practice for assigning DNS to servers, their roles and its effect on the network. Site #1: Wind...
Hi, We have exchange server 2007 named exchange.smile.local(192.168.1.5) in our local office. it receive the external from 3rd party software, we have implement the UCC certificate(mobile.t...
