Time Tested Network Design & Methodology Solutions: 176 - 200 of 265
Current network architecture: First .jpg below depicts current network. All static. Default route on 6506 points to Juniper. All traffic internal and external funnels in/out the 4.5meg se...
Hello, Can a new Cisco 3560 layer 3 switch co-exist in a LAN with two layer 2 switches?  I have to buy another switch to increase ports.  I want the layer 3 switch functionality for future ...
I am trying to setup a small business network. This is what I have been given to work with: ISP: Optus Naked ADSL - Siemiens SpeedSteam 4200 Modem IP Address for Modem / ISP Settings Ro...
Hello,  I just inherited a network and am trying to familiarize myself with it. The WAN network is: 2 Internet routers running HSRP and BGP. 2 ASA Firewalls (active/standby) I have...
Hello Team I about to embark on Migrating our current IP Scheme (Public ) to a Private Network. This is going to take some planning and i am looking for some pointers from you on what i n...
I have this very pesky problem. I have a BR1310G-A-K9 in one building, acting as the Root,with ethernet connection into my network.This device is mounted in the window of an office on the seco...
Hi. I should have asked this in my original question, but this is related. If I have multiple switches connected along the way over a 50 mile span, the trunk ports on either side of the swi...
Hi, I want to verify whether or not our network devices are capable of implementing QoS (mainly for future VoIP traffic). We have two Netgear FSM750s managed switches, a couple of Netgear G...
I have taken over a network that is really sloppy.  I have been putting off changing the network but it really needs to be done.  Here is my current setup. I have 3 networks that all tie to...
I'm seriously considering changing my corporate network from Class C (192.168.1) to Class B (172.16-31). I have computers with ODBC adapters with identical names but two very different configu...
I have 4 cataylst 3550 switches with an L3 IOS recently installed. These 4 switches are to be used at different sites connected via Telewest National Ethernet circuits. I understand how ...
I`ve just started to work with Nortel switches. Have always been working with cisco. When I created a new vlan on a cisco router I created a vlan and assigned a ip address and mask. With norte...
Hi guys I am trying to install VPN Client 4.8 on my computer but I am getting the following error message The CISCO Systems VPN Client installation has detected that an MSI based CISCo ...
Hi! We have a lan with 240 units on the same subnet. 192.9.110.0. Now we are moving our servers (50 nodes) in to our own site. and we want to seperate the servers on its own subnet. 192.9...
Hi experts! We are close to buy a cisco 526 lan controller at one of our offices.  We have a ASA5505 ( sec + bundle ) at that office. I want to have 2 different SSIDs and i will use 2 APs. ...
I have a W2K3 ENT 64-bit Cluster for SQL 2K5. I added two new nodes to the cluster and removed the older nodes from the SQL cluster. They are however still nodes in the MS Cluster. When I atte...
I have implemented a child domain of my company's poject office in different city. Lately I found out that this is not the right domain model for the company whch has no domain server redundan...
I"m working with someone who is attempting to use a NetBoot server for imaging Macintosh workstations.  NetBoot works off BootP which is a broadcast and is not automatically forwarded between ...
The other day I asked a question here regarding getting these two machines to see each other on the network.  That question was answered.  and I can now see and ping both machines (at the time...
OK, I am trying to get some input from people who have ACTUAL experience with the situation or can speak authoritatively about it.  Just linking to cisco.com's various pages on relicensing of ...
Our current network consists of an Active Directory on Server 2008 with a single domain: 1 Main office with 15 workstations, domain controller, exchange server, file server, database server, ...
Hello gurus, in an attempt to secure my network , I have the choice between 2 appliances. Juniper SSG140 and Fortigae 224b. anyone can guide me ? thanks. PS. My layout is as follows. (...
Hello, I am trying to update our network while preparing my End of year it budget so i would like your help in upgrading our network...Also, will open 2 more questions after accepted solution...
I have 3 virtualized windows 2008 serverson esxi  that are hardware load balanced and 2 2008 sql servers in a 2008 server cluster. I have an identical trio of virtualized 2008 web servers on e...
hello,, i just want to clear something about database recovery.  lets say i have  sql database and have full back up from sunday and differential monday tuesday, then database crushed on we...
