Hi, I know it has been alot of these kind of questons, but didnt find any solution that I undestood :S. I am currently trying to understand the process and the thinking behind of these activit...
Backup Exec 12.5 running on Windows Server 2003.
For "Logon Accounts" i have a service account i created, that is the default logon account.
There is also a "system logon account" that i...
Hi there,
I'm in need of some expert help, I've got myself in over my head and have run out of ideas! Basically I'm trying to set up a 3com Baseline 2924-SFP Plus managed switch with 4 vlan...
I'm trying to work up a propsal to get our bandwith upgraded. What my bosses want is a report of how much of our current bandwith is being used by FTP, HTTP, and custom ports used for internet...
My Company has serveral webservers in our office. They are important but not critical.
We also have one critical server being hosted by a third party because they offer reliable service and...
Hi All,
I created a simple .bat file to test the server connections every day.
I want to change it in the way that the ping command will be sent only 2 times instead of 4 (but only in that...
HI lads
I have a HPO desktop, fairly new and reliable HW including a gigabit Ethernet connection.
I have be dabbling in openfiler and have found it to be very reliable and easy to use.
Attempting to connect a cisco 3020 with an HP 5308 procurve Switch. When using VLAN 1 the etherchannel using LACP works with no issues. If we attempt to reconfigure and use a VLAN other tha...
What happened to the days of open source and free for network monitoring? Back in the day, these products MRTG and Big Brother use to be free. Anything out there that is comparable, pretty t...
Is there any command that works similar to "removing the network cable and re-plug in".
Hi Everyone.
I have a client that has had vlan's configured on their network for about 8 years. I have a decent amount documentation on the configuration, just not really sure how to edit V...
I am trying to route the internet to our private network.
I have a Cisco switch (unmanaged) that is feeding clients. On that switch I have a server (2k3r2) and 10 clients.
The private IP...
Hi, i have a cisco GSR 12000 series router with a 5 port gig line card
also a 7301 series router with 3 port ethernet cars.
Is flow control on by default even though the show int command sta...
We are facing a problem with Panasonic FAX with Cisco ATA line; we can send Faxes to any Hardware Faxes vendors expect one Vendor which is Using Soft Fax with analog line, Please note that thi...
I have access to the #ENABLE and #CONFIG sections of the command line in my Catalyst 3550 but I'd like to know how I can enable the HTTP service and adding a user account for HTTP access to a ...
Hi ,
I have a windows dhcp server handing out 192.168.0.x addresses. I would like to add another dhcp subnet to that server 172.20.9.x. This new subnet is connected to a 3560 switch and I hav...
Cisco Switch ports connection
If I know an IP address of a computer, for instance 10.13.2.1/24
let's say it's in vlan 2. How can I tell to which port of the switch it is connected to, when...
I just got a DS14 from ebay and I totally for got how to setup a RAID to the server via serial port. Could you help me?
Is it possible to have more than one VIP address? I am new with netscreen and it is already configured with one VIP. I'd like one more since I am no longer able to add virtual ip services with...
There is a WAN link between campus A and campus B, please see the following diagram:
Internet---------F/W-----Core router/switch (campus A) ----ISP Cisco router <-------WAN link-----...
I just go a new (new to me but otherwise used) Gateway Laptop. It is an M350WVN, 3 mhz P4, 1 gb, XP SP3. Firewire port, wireless card, and ethernet adapter are standard. I am not using Firewir...
Hello All,
I'm looking for a free basic server monitoring software. I am really interested in watching the basic server performance statistics and monitor the overall functionality of the s...
I have 5 computers that access the internet via an AT@T wireless adapter (GSM).
They also need to communicate and share files with each other so I tried to put in a router and connected t...
I installed Hobbit on my CentOS server exactly according to this guide:
http://en.wikibooks.org/wiki/System_Monitoring_with_Hobbit/Administration_Guide/Compiling_on_CentOS
The entire pro...
Hi Gurus,
Please I need some expert help we have two office one in London and NY. The two office are not connected by any means please can you tell me how I can connect them. I am looking a...
