Time Tested Network Operations Solutions: 1 - 25 of 125
I am trying to connect via Cisco VPN client.  Tech support at the remote computer end has no idea what the problem is, so for now I'm on my own.  When I try to log on, I get the error: "Secure...
Hi Guys 1. I want to download Cisco Network Assistant 2. I have different models of cisco Switches in the Network 3. would i be able to manage all these different Cisco Switches with CNA ...
I'm going to use a crossover cable for the first time today.  Should I set the TCP/IP settings on auto or set them manually?   If I set it up manually, presumably both NICs go in the same s...
We have a windows 2003 server providing access to files and folder shares, but is not a true "file server." One of our biggest clients expects us to provide logs showing when a file was opened...
I try to use the switch(config)#interface range command "interface GigabitEthernet1/0/2 -24" and the switch allows me to do it, but only interface GigabitEthernet1/0/3 is configured, I have cl...
I am going to be setting up some webservers.  I know my average connection rate (2000 per second) and the file size transfer (5k).   How do i calculate how much internet bandwidth I need to su...
Hi ! I am trying to get a Cisco 4506 to do VLAN Trunking and Ling Aggregation to 2xDell PowerCOnnect 5316 switches which we have installed in our DELL Blade center. This seems to be somewha...
As the title suggests can anyone provide me with any typical setup guides, tips, tricks or best practices in setting up a Management VLAN?  So far I have not been at a job that required or had...
I have a relatively simple network. However, my internet access is provided by a third party ISP, which does not let me access the router. So I have no way of accessing the log files that the ...
I have two sites.  At the main site, I have two Cisco 2811 routers.  One is connected to the Internet while the other is connected to the MPLS circuit that connects our other offices to the ma...
I can pass traffic thru the switches but when I'm logged into the switches on the console port, I can't ping anything, not even the default gateway.  here's my config: version 12.2 no serv...
Hi all, I need some advice on how to achieve the following: Site A has 1 router (Router A) Site B has 2 routers. (Router B1 and Router B2) Site A and Site B are connected via 2 leased ...
We are trying to find IP adresses for some computers and all that we have is the MAC address we got from using show mac from our Cisco switch. Is there a way to find the IP address of the m...
I wanted to get some expert opinions and a couple of questions answered on a network configuration I am planning.  Here is what I currently have.      Router           |    ASA 5520     ...
I am trying to use my CISCO ACS to grant access to Enable mode. When an admin Telnet into a switch and types, Enable the password that follows is his ACS password and not the local stored p...
Does anyone have any example code (VB / C#) on how to send a magic packet out?
This PC won't connect to the Internet. I try to ping the router but keep getting "ping transmit failed error code 5". I also notice that I can't get the network connection up (no icon showing)...
Hi,     I'm changing some network settings on a 7940 cisco phone.  I'm able to edit some things but when I try to edit the "operational vlan id" I loose the softkey "edit"  any ideas on what ...
Please help me in reducing the utilization of cpu for 'Cat4k Mgmt LoPri' process in Cisco 4503 switch. we have got 5 similar switches in other floors having the same problem. CPU utilization i...
I have a linksys SRW2048 in a home environment.  We have Belkin wireless G router. I am trying to setup VLAN's on the switch to segregate traffic for their home entertainment (HE) system away...
Any one has encountered problem with clock set of Cisco 3560 Switch? I have 2 Cisco 3560 switches with model type and IOS version as below: Cisco IOS Software, C3560 Software (C3560-IPBASE-...
Hello guys.  I know that limit by quota in websense sets a limit of 60 minutes for a user to access a website.  My first question is is this 60 minutes per day, per week or per year?  And does...
I'm using an incredible open source program called http://nagios.org. For anybody who has set this up already, how do I monitor more OS services? For example, my Nagios server is installed on ...
Hai, i am doing one project in C# windows application.This project is used to interfacing with another one data.I can transfer  data to that device by using TCP/IP with port 25.But When i tra...
I have tried to use RUNAS as well but to no avail. I would like to be logged onto my XP or member server and bring up the DNS mmc (DNSMGMT.MSC) successfully.  I have been able to bring up a sn...
