I am trying to setup Exhange 2k7 running CCR - I have 4 servers for exchange:
I have 4 servers that I will (meaning they don't have exchange on them now) install the following roles:
1 Hub t...
I have tried to use RUNAS as well but to no avail. I would like to be logged onto my XP or member server and bring up the DNS mmc (DNSMGMT.MSC) successfully. I have been able to bring up a sn...
Any one has encountered problem with clock set of Cisco 3560 Switch? I have 2 Cisco 3560 switches with model type and IOS version as below:
Cisco IOS Software, C3560 Software (C3560-IPBASE-...
I'm changing some network settings on a 7940 cisco phone. I'm able to edit some things but when I try to edit the "operational vlan id" I loose the softkey "edit" any ideas on what ...
Greetings Experts.
We are getting ready to install an HP SAN. One of the prerequisites/recommendations is to have is sitting on a separate VLAN. We have 4 NICs on the SAN with two each atta...
I'm using an incredible open source program called http://nagios.org. For anybody who has set this up already, how do I monitor more OS services? For example, my Nagios server is installed on ...
I have a quick question. I used to make changes to my router by editing the startup config and scheduling them to reload after hours. We recently upgraded our network with new routers (2811s ...
Hi Guys,
I have two nics in a server which receives reports from one network (192.168.120.x) and is queried by our main network (192.168.125.x). The 192.168.120.x network is a VLAN which g...
We are using Cisco ACS to control network access. By default the XP Authentication is set to Smart Card or other certificate. We need to change it to PEAP manually. We have over 400 XP. Can we...
Hi All!,
We are trying to open access to our FTP server from the internet. We are unable to access the FTP at all.
the FTP server is 10.10.10.4
im pretty sure it is an access list issue a...
I am trying to monitor about 20 machines, i am trying to get a weekly report of the health of these machines. I am wondering other than going to each machine and setting up preformance monitor...
Hello guys. I know that limit by quota in websense sets a limit of 60 minutes for a user to access a website. My first question is is this 60 minutes per day, per week or per year? And does...
I inherited a network here at work where there is no DHCP and everything has a static address. This is great because I have a list of each device and it's address, so I can usually find thing...
I am trying to setup my home network and seperate a guest network from my private network. The problem I am having is my 3524 switch is not seeing the second vlan. Here is a rundown on my home...
Hi all,
I am currently setting up Nagios 2 on Debian Etch.
I have come to a crossroads in which type of monitoring to continue with:
1. SNMP
2. Nagios client.
I was wondering if ...
We're having problems authenticating users to wireless and VPN with a Domain Controller that runs Cisco ACS. We're using Radius for authentication on the ACS server. The server is 2003 SP2.
Ok, Ill try to explain this the best i can,
Have the workstations plugged into the switch(cisco 3500), then from the switch, fiber runs to a breakout point which runs to a fiber/cat-5 conver...
Ok I have a complete public class C network that is subnetted and distibuted into vlan's at a core router. The first half of the class C is carved out into Subnets of 255.255.255.224 and thus ...
Need help making a VBS script to do the following for a Cisco IAD2420...
The script logs into a 1st box that is home to the necessart files. then from that box into a 2nd box. The second box ...
on a 7/8 pc network, all ethernet and no wireless clients, d-link router/gateway. problem is with 2 of the clients they cannot connect to the internet or to the network application. all other ...
2 questions
How do you change the version of SNMP running on a windows server from snmp 1 to snmp v2c
How would I check what version of SNMP is running on a windows server?
Tha...
Have a Comcast Fiber Connection coming into my office. With a Class C 256 Wan IP addresses. They bring the connection via fiber to media converter which takes the connection back to cat 5. ...
I've got an IP cam wich i can access from my local area network just by typing 192.168.1.105 (Its address) on the browser of any comptuer on this network.
HOwever I would like to access thi...
I'm looking for a way to monitor/audit our network. I'd like to monitor our Windows and Linux servers, switches, router, etc. I'd also like to monitor disk usage, traffic flow, equiptment fail...
I have a user that when he tries to connect to the VPN. (Sometimes) he gets this error.
Unable to connect
Reason 413: User authentication failed.
I think it is that he is just putting ...
