Time Tested Network Operations Solutions: 51 - 75 of 171
I just bought a new Dell 1525 laptop and am trying to intergrate it into my home office wireless network.  The laptop can see and open the desktop shared files....the desktop (XP Pro) can see ...
I have a Verizon Broadband wireless internet card that worked very well  for 30 days. I used to connect to the  internet through this card while also syncronizing my PDA which uses MS Outlook....
I'm using an incredible open source program called http://nagios.org. For anybody who has set this up already, how do I monitor more OS services? For example, my Nagios server is installed on ...
I am trying to setup my home network and seperate a guest network from my private network. The problem I am having is my 3524 switch is not seeing the second vlan. Here is a rundown on my home...
Hi, 2 questions How do you change the version of SNMP running on a windows server from snmp 1 to snmp v2c How would I check what version of SNMP is running on a windows server? Tha...
Hi Guys, I have two nics in a server which receives reports from one network (192.168.120.x) and is queried by our main network (192.168.125.x).  The 192.168.120.x network is a VLAN which g...
Hello, I have the following configuration: My Company: UC500 Lan 10.192.10.0/24 Wan 81.1.1.1 (static ip) Home: ASA5505 Lan 192.168.192.0/24 Wan 61.1.1.1 (dynamic ip) And want to set u...
We are experiencing a very strange problem on our network; every day exactly between 10-10:30AM, our network speed including Internet speed slows down. We have a 1.5M T1 line that slows down t...
i tried copying the ios image of cisco switch 3550 to my tftp server (Solarwinds.Net TFTP Server). I was able to copy the image to my tftp  server (thats my laptop).I tried uploading the image...
When I connect to a remote network using Cisco VPN Client I loose access to my local LAN. I have made sure that the "Allow Local LAN Access"  option is enabled but when I connect and then v...
After putting in a new firewall a couple of weeks ago, the time sync stopped working and now all the client PCs are out of sync with the Domain Controller.  We have about 9 servers here and I ...
Hi everyone. I have recently gone to a test and I was given these4 questions. I would like if possible for you experts here to confirm me if I have answered each of them correctly and if I hav...
I am running windows XP and I have several network connections (such as LAN1 - over the wired network card, LAN2 - over the wireless card, etc). How can I route a certain application's traffi...
Ok, Ill  try to explain this the best i can, Have the workstations plugged into the switch(cisco 3500), then from the switch, fiber runs to a breakout point which runs to a fiber/cat-5 conver...
Hi,  We took the Windows 2003 server out of the picture purposely and tried to set up a previously connected Win 2000 Pro PC straight to a little router.  While logged on as the local user (no...
I'm looking for a way to monitor/audit our network. I'd like to monitor our Windows and Linux servers, switches, router, etc. I'd also like to monitor disk usage, traffic flow, equiptment fail...
Silly question. I have a UC500 box Im setting up to play with and he manual says enter the default system administrator username  and password for the UC500 Can anyone tell me what this is ...
Hello network experts, please HELP, I have configured ethercnhannel between cisco catalyst 2950(10/100) and cisco catalyst 2960G(10/100/1000) on 2ports Here are my questions 1. How d...
We recently installed a new ASA 5510 firewall at our office and so far it's been working great with one exception, i am no longer receiving any meaningful information from trace routes, it loo...
Does anyone know of any preferably FOSS software that will allow you to mange the Cisco 79xx series of phones remotely.  We have a large amount of phones that are staticly assinged and are mov...
Hello All,       I have just been given the management role overseeing our system adminstration area.  I come from project managment in the programming/DBA arena.  As a manager I am looking...
We have a network with 4 VLANs. The DC resides on VLAN1. Any computer on the same VLAN as the DC can surf the internet without any problems. All the computers on the other VLANs cannot. They a...
Hello, I'm going to be setting up a site to site VPN using our Cisco ASA 5505.  The two sites are laid out like this:  Site1 has an a Domain Controller running SBS 03 and is setup as a DNS, DH...
Hello Experts, I am a little confused. I have got two 3Com 5500G-EI 24 Port Switches, stacked together, building my network backbone. Attached to them I have got a total of sixteen 3Com 450...
Hello, I have a Cisco 2950 24 port switch with no gigabit ports for trunking.  I'd like to plug this 24 port switch into one of my other Cisco 2950 48 port switches to increase the connecti...
